Trailer questions
/ Trailer questions #21
You have trailer sway pulling with a Ranger. Shocker. Please do everyone a favor and sell the trailer or buy a bigger truck.
/ Trailer questions #22
/ Trailer questions
Thanks, I believe it goes deeper than that though, I also have a couple of truck trucks, (4wd) early Dodge trucks and the same experience
/ Trailer questions #25
As others have said, if you can lift the tongue by hand when the trailer is unloaded you have a tongue weight issue. A simple test to prove this out will be to go to Home Depot buy seven bags of sand (60 lbs/bag) 420 lbs total and strap them down as far forward as possible. Take a test drive. U can return the sand bags when the test is done. You may also want to consider a load distribution hitch.
/ Trailer questions #26
I tow my 18ft car hauler with B2650, la534 loader, BH77 backhoe, with my 2006 4.0 L V6 Toyota Tacoma, tow package springs and shocks, I believe 6500lbs rated. Calculated about 5500lbs trailer and machine total. Rides beautifully! It's a way lighter trailer than yours, about 1800lbs, but my "compact pickup" does just fine. No rushing, properly weighted tongue, properly adjusted dual electric brakes, properly inflated tires... Etc... I don't have a scale to check the tongue weight, but I compress my truck rear springs to put the truck axle to about one inch of the rubber bumpers.
/ Trailer questions #27
Your trailer definitely needs some attention. I don't know what's wrong but I know your little truck should be able to pull that trailer empty. Your trailer looks a lot heavier than mine though, so I can't say you should be able to tow your tractor on it.
I used to tow an L2650 (2500 lb tractor + another 2000 lbs for loader and backhoe) behind a 1995 S10 ZR2 without trailer brakes (extended cab, 4WD, V6). The trailer registration says 2100 lb empty. I tow it with my 2016 Colorado with trailer brakes now.
I will say I go slow and just let the engines rev up on the hills, but both trucks have handled it fine. And other than the trailer bouncing straight up and down while empty, it's never swayed side to side on me. Here's a picture of it behind my Colorado: IMG_20160515_171133794.jpg
/ Trailer questions #28
As other have said, look under the trailer and see if your axles are curved up or down in the middle of the axle. If they are cambered up, the axles haven’t been overloaded. If they are cambered down it could have been overloaded before and that would make the tires wear on the inside bad. I had a boat trailer that did that with wider tires than what came on it. I would also check the leaf spring and metal brackets to make sure they aren’t wore bad to give the axles slack to try to walk back and forth. I would remove the ramps because they will definitely act like a spoiler at speeds over 35 or 40 mph. Living in florida with fairly flat ground, you might be getting close to the max weight your truck can tow, but you don’t have to worry about going up or down a steep grade. If everything checks out fine, I would put some more weight on the tongue.
/ Trailer questions
I'll check out the trailer this weekend and report back
/ Trailer questions #30
Another TBN member had posted this video on another trailer post, but it is very informational if you have not seen it.
Dangerous Trailers.Org Presents Trailer Sway 11 - YouTube
I love that video. Such a great demonstration to people who dont (yet) understand the importance of balancing a trailer.
I towed about 6k behind my 2009 Tacoma TRD sport. It handled it & was probably a hair overloaded, depending on how accurate my load estimates were. It was all tapped out on brakes, suspension & engine (in order of importance). I promptly got a beater F250 as I planned on hauling reasonably often.
/ Trailer questions #31
Sure seems like a popular topic of people trying to convince themselves to make a truck do more then what is realistic; just cause the specs say you can.
I've read this thread ad infinitum on the tundra forums.
I don't care what your Ranger is rated for it is beyond its limits. Pulling is one thing, chassis length also contributes to handling, braking even if brand new is marginal.
I would strongly suggest you binge watch some this guy's videos on towing, 1/2 ton versus 3/4 ton, short versus long trailer etc.
Big Truck Big RV
- YouTube
We've lived this long not doing things right, we strive to learn and make adjustments.
This is one topic where mental outlook on towing needs adjustment.
Also from Tractor Mike videos on loading tractors there is one on vehicle being on an incline and negative tongue weight. Please check out his channel and watch his videos as well.
The Danger of Negative Tongue Weight - YouTube
When loading trailer use wheel chocks on both sides of trailer.
To trust the mechanical dog of a Ranger transmission to hold the truck and trailer is asking for a transmission repair job and possible severe damage to load and operator.
Something to think about.
/ Trailer questions #32
The build is actually awesome .The frt/back ratios look OK to my eye.
Here are my thoughts.
The ramps being full plated might be the actual cause as they are more or less wind catchers.
I'd be very tempted to remove them (if easily done) and try another speed run.
My 2 cent guess is the problem lies there.
They act as wind anchors, so to speak.
Otherwise the ratios look good.
And, please let us know of the results.
/ Trailer questions #33
Boy you found the button for flushing out expert opinions ! Appreciate your candor in the OP saying you don't know how to load a trailer. You now have north of 30 posts telling you how to do things, acting like safety experts, etc. In there somewhere are several very good pieces of advice and worthwhile assistance. I'll stick my nose in and summarize (which is OF COURSE my opinion.)
[Note: I wager this trailer was pulled behind a dump truck in the past, hauling some sort of heavy gear by people who would never notice if it were fishtailing, could not see back there, would get the load about right just by eye ball in less time than reading this & couldn't care less...]
1) Yes, too little tongue load is why you were fishtailing whether loaded or empty.
2) At legal highway speeds aerodynamics was never a part of your problem and won't be.
3) There are too many rabbits mentioned to be chased. One at a time. The faults in the trailer, the light loafered truck, the which-end-goes-on-first, etc. All rabbits to be chased or in some cases discarded as irrelevant.
Easy one first: It flat does not matter which end goes on front or back. Any way is OK as long as you have adequate tongue weight. As another suggested, yank those hefty looking ramps off, tie them on the front of the trailer and it better tow empty without fishtailing. If not, stop until you find out why.
Two: Trailer fault is unlikely -- tire wear may be abuse or they may be the worst tires pulled off 3 other trailers before the thing was sold to you. Worry about that last.
Three: That poor little maligned Ford Ranger. As described so far, your task is non-commercial, occasional, hauling an L2501 which weighs around 2500lbs. No, the loader is not adding 1000 lbs. No, that trailer probably does not weigh 3000lbs. Go weigh it if it seems important. Assuming you tow the empty trailer OK now, I say you can also tow the L2501 with loader on it provided you get the CG far enough forward.You might have to back on to the trailer in order to get decent tongue weight. I suggest use a yardstick and measure the hitchball to ground distance first with empty trailer and then with the "initial try load position." Aim for a drop of around 5 or 6 inches at your hitch. Whatever leaves the rear axle of the truck at least an inch or so (as another guy suggested) from the rubber stops. Play with that a little moving the load fore and aft until it is lowering the hitch to the level just described. You will then be just fine towing with the Ranger in "easier terrain," staying out of the bigger mountains, etc. Either have good brakes on the trailer and a well-adjusted brake controller on the Ranger or else leave 15 extra car lengths between you and where ever you plan to stop.
Fourth: If all this "let's try it" fails for some reason (I don't think it will...) then you said you have bigger trucks. Use them. End result may be using the Ranger for short hauls and lighter cases and switching to the heavier trucks when you have extra load, longer hauls, steeper hills to pull, etc. You'll figure that out.
/ Trailer questions
I appreciate all the comments, just got home now and am back online, I brought the trailer home with me along with some other projects I plan to tackle before going out to the property again.
I drove the trailer 130 miles home at 60 mph without an issue, Im not gonna say I never felt a little queasy but for me Im a little hypersensitive to fishtailing a trailer cause of a past negative experience.
tent
I plan to read and re read the comments in this thread and figure out what the problem is, first I will start with cutting the ramps off and making them so that they are able to fold down onto the top of the bed.
I brought home my small Kubota for some much needed love and attention. I guess the way I had things set up was just right.
/ Trailer questions #35
Before you cut the ramps off try adding a little weight to the front to counter balance them and see if it makes any difference.
/ Trailer questions
This on the other hand wasnt happening.
Taking it to a water supply down the road and anything above 20 had me changing my shorts
The last pict is where it actually rode best, 25ish MPH seemed OK
/ Trailer questions #37
OP....correct me if I am wrong but those wheels/tires look like 8" ones to me. Cute little trailer but I have to wonder if it was a home build off a boat trailer? :2cents:
/ Trailer questions #38
Geeze. I did not realize during the prior discussions that the trailer is so short. Limits your ability move things around a whole lot. Still,looks like you made it work.
/ Trailer questions
.5x8.0-10
10 inch
/ Trailer questions
Thats what she said:thumbsup:
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
