Filling a divot
/ Filling a divot #1
tree grower
Cuttingsville, VT
Ford 1210, Bobcat 742B, John Deere 1050
My Five Star post hole digger's 'business end' is a 2" shaft with a 7/16" hole for a shear pin. Due to stony soil I do not use soft shear pins, but grade 8 bolts instead. The torque of the shaft and the resistance of the auger still bends the bolts to a modified S shape, and it is necessary to cut the bolts out with a torch in order to remove the auger. There has developed a divot at the three o'clock position on both sides of the 7/16" hole which allows the bending of the bolt easier than if the shaft were perfectly intact. I think the best way to fill in this divot is to insert a non-ferrous 7/16" rod, fill the divot with hard-facing rod, drive the 7/16 rod out, and grind the weld smooth. I can't imagine copper standing up to the heat of a welder, so what is a reasonable alternative?
/ Filling a divot #2
Insert a carbon rod and weld up the divots.
/ Filling a divot #3
Can you just drill it out to say 5/8” or 3/4” and use a bigger pin? I am not sure why a shear pin holding on the auger is necessary. My auger has a hexagonal shank. Even with that the bolt that holds it on is large - 3/4” maybe.
/ Filling a divot #5
I understand you have stony soil, but if the Grade 8 bolt doesn't shear when it's suppose to, what breaks?
/ Filling a divot #8
Post-hole diggers for AG tractors and CUTs use 2" round shafts and shear bolts. Industrial PHDs (e.g. Danuser) use hex shafts and do not rely on shear bolts.
Our local rental yard switched their Grade 2 or 3 shear bolts to Grade 8 because they shear cleaner, without bending.
/ Filling a divot
Lots of good answers! If I used soft shear bolts, I would need at least one per hole X # of holes per day. Nothing breaks, but I have bent an auger and stalled the tractor. I just try to be careful. I don't have extensive experience w/ post hole diggers, but it appears that this Five Star made in Oklahoma is made to be used with no scheduled obsolescence. I like the idea of drilling the hole out to 1/2", 9/16", or 5/8", but I don't see how that could be done unless I disassemble the gear box and take the shaft to a machine shop. All very doable I suppose, but I don't really need another project. The hardened bushings option sounds good, but that would also involve drilling the shaft to the depth of the bushings. Where would I find carbon rods? What are they normally used for?
/ Filling a divot #10
Someone used to make kits available. The rods were an assortment of diameters to accommodate building up oblong holes in trailer drawbar hitches etc. Simple to use and effective. Drop the rod in the hole and weld up the void. Pull rod out.
I haven’t seen them available for years. Perhaps yomax4 knows of some.
I found this link. Rods like this should work.
WeldingSupply
/ Filling a divot #11
2" round is the standard for 3pt PHDs. 2"hex or 2 9/16" round are the standard for bigger SSQA units. They are almost always hydraulically driven & protected by relief valves. Not to mention generally stronger than the 2" round.
You need a sheer pin for the PTO powered ones. Most have a sheer pin between the PTO shaft & the gearbox. The pin holding the auger onto the gearbox may or may not be a 2nd sheer pin. I'd assume the PTO shaft would be the weak point rather than the gearbox.
My old Leinbach 3pt PHD actually had 2 pins at 90 degrees to each other an inch or 2 apart on the gearbox output shaft. Most or all the 2" round augers have had matching holes as well. My cheap 12" auger had the holes tearing out a bit despite using both pins. It wasnt bad enough to bother fixing before the PHD & auger ran off with the old tractor. But in that case I'm sure the auger pins weren't ment to be used as sheer pins, only the sheer pin on the PTO input to the gearbox.
My new hydraulic SSQA PHD is 2" hex. I have much bigger problems if that ever strips out or sheers a bolt.
/ Filling a divot
I haven稚 seen them available for years. Perhaps yomax4 knows of some.
WeldingSupply
I think I will try these. Looks like the easiest option.
/ Filling a divot #13
WeldingSupply
I have a bunch of assorted carbons I have been trying to give away. Also once fix'd you can case harden the hole to give yu a little better life before oblong sets in again. There are a couple of case hardening powders out there that work well.
/ Filling a divot #14
I would think that ALL skidsteers had to use hydraulic PHDs, as they have no PTO. Most industrial tractors (Case 580) do not have PTOs, tho some clearly do (Kubota L45). I have not seen any PTO-driven industrial strength PHDs, for CAT2 or bigger tractors.
Regardless, there ARE hydraulic PHDs for CUTs, and the 3 I have owned (e.g. Worksaver 724H) all used the 2" round shaft.
As for welding up the side or edge of a sloppy hole in the shaft or auger, nothing fancy is required: just fill the divot with weld, and trim the shear bolt hole to a nice sharp edge with a die grinder.
/ Filling a divot #15
Do you have a picture of it?
I am envisioning something like this:
If it is similar why would you need to dismantle the gear box or take it to a machine shop to make it accept a larger bolt? Just put the auger on, stick it in the ground a little bit to stabilize it, remove the 7/16 bolt, run a 1/2 drill bit through both the auger and shank at the same time, then run a 9/16? then a 5/8? and so on however big you want to go. Taking 1/16 at a time should be pretty easy drilling with a hand drill.
If you want to go the carbon rod route they work good too I have used them but if you tore up the 7/16 bolts you had what is going to be different going forward?
/ Filling a divot #16
If you drill to increase the hole size like bdog suggested, perhaps
increase to 5/8” or even 3/4” D. But use a Grade 2 bolt first. Increase to Grade 5 and then 8 if necessary.
/ Filling a divot
My gearbox is pumpkin-shaped. I hadn't thought of stabilizing the shaft by drilling the auger into the ground--Duh!, but that should work. If I could gradually increase the hole size to 3/4" , I could use cat 1 top link pins which are everywhere around my little farm.
/ Filling a divot #18
The one thing your not considering with drilling a bigger hole. The next thing to shear might just be the shaft itself. It could break right where the hole has been drilled.
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
1008 (A61166)
1008 (A61166)
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
2015 FREIGHTLINER M2 26' BOX TRUCK (A59906)
2015 FREIGHTLINER...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
