Your Advices for New Rotary Cutter Design
   / Your Advices for New Rotary Cutter Design #101
I used the guide wheels from a New Holland Hayliner Baler.
   / Your Advices for New Rotary Cutter Design #102
As far as the removable side is concerned, 30 years ago or so, King Kutters were available with what they called a "removable hayside" so you could use a rotary cutter for mowing hay that you would bale in the traditional manner.
   / Your Advices for New Rotary Cutter Design #103
My last sidewinder cutter had that also.
   / Your Advices for New Rotary Cutter Design #104
I don't know if it's feasible, but I'd love to have a rough mower that could offset for mowing closer to fences.
Both Bush Hog and Woods make a cutter with hydraulic off set. A cylinder moves the cutter to the right. For Bush Hog check models 3008 & 3308. Woods is model DSO12.5
1. Tool free height adjustment of the tail wheel.
2. Enough angle on the tail wheel so it doesn't wobble at higher speeds.
3. replaceable skid wear plates and optional front wheels
4. A PTO coupler with a locking collar, so you can hold it in the open position as you slide it onto the PTO shaft (I had an older Rhino that had this type)
5. Chain or fabric debris skirts.
6. Generous top link pivot for uneven terrain.
7. Smooth underside to facilitate cleaning and minimize debris buildup and corrosion.
8. accessibility to all grease zerks ( I have a Landpride, the zerk on the PTO shaft near the gearbox end is a PITA to get to)
9. If a shear pin style, make a carrier to keep spare shear pins.
"7. Smooth underside to facilitate cleaning and minimize debris buildup and corrosion."
Is there any other reason for 7 ? How important is the smooth underside from 1 to 10? Smooth underside & strong deck is a real challange. Hard to accomplish both. Consider woods, they have a strong deck but don't have smooth underside.
   / Your Advices for New Rotary Cutter Design #106
Build it with a double deck. Smooth both top and bottom. Reinforce between the top and bottom of the deck. Make it higher at the center/gear box mount area, taper towards the outer edge. Sort of like corrigated cardboard.
Or do all the reinforcing on the top of the deck, but try not to make places that will hold water when it sits outside.
A ring to prevent the blades from hitting the upper surface of the deck would be nice too.
Well, double deck might be optional and it is a good idea. I thought too.
how do the blades hit the upper surface of the deck ?
   / Your Advices for New Rotary Cutter Design #108
I am not sure if the blade pin hole wears, the blade pin gets loose, the output shaft wobbles, the blade holder get bent? But I've seen decks where the top has a semi circular dent from the blade tip. Just search machinery for sale sites and I am sure you will find some listed with pictures that show this damage.
   / Your Advices for New Rotary Cutter Design #109
Bent Blade from a rock will do that.
   / Your Advices for New Rotary Cutter Design #110
Build a mower like the Woods RM990 & RDX990 which have swinging blades, but in a batwing so it follows the ground.
That cuts at least 90 wide maybe up to 10?
Also make it so it will run on 32 PTO HP or less.
Cutting heights oh 2 - 12?
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
Zero Turn Mower (A55853)
Zero Turn Mower...
2022 John Deere 1025R (A53317)
2022 John Deere...
