Good morning!!!!
   / Good morning!!!! #93,911
Harvey, good to hear from ya'! Is that one of the Jarrell storm shelters? Mind I ask roughly how much?
Nice pic Mostly. I like boating too.
Nice pic Ron, I'm sure those can be fun to watch for extended periods. Beautiful.
   / Good morning!!!! #93,912
Yes it does!! From section 5-36 page 288 of my owners manual:
"When certain conditions are met, the
engine is automatically decoupled
from the transmission
while the shift
lever is remained in D (Drive). In this
ECO Coasting mode, the engine
stays at idling speed to reduce fuel
consumption and increase coasting
distance. The engine is automatically
coupled back again when ECO
Coasting deactivation conditions are
met. Please refer to ECO Coasting
activation and deactivation conditions"
The conditions for automatic coasting go on to list that the car has to be in Eco mode and in Smart mode, cruise off, the accelerator or brake pedal is not depressed, when going 55km/h to 160 km/h and the road gradient is in the range of -5% to +5%.
There is no engine drag at all and it really just goes and goes. Think soap box derby.
Don, a few years ago I had a Honda CR-V automatic that did something very similar, but it wasn't documented in the user handbook.
I forget the exact sequence of events that initiated it, something like cancelling cruise control while not using the accelerator pedal. On a long fast downhill gradient the engine revs would drop to a near silent tickover compared to wind/tyre noise and a feeling of weeeeeeeeee. The mode cancelled as soon as accelerator or brake pedal were pressed, so not really unsafe in the same way that a gear selector moved to the neutral position would be, though wouldn't want a judge to have to rule on that if it is listed as coasting in the user guide.
   / Good morning!!!! #93,913
Beware of renting an excavator. You will fall in love and your life will never be the same. I still get giddy about the time I got to play on a Cat 375, quiet power, unbelievable power.
:) That is so true.
A friend once persuaded me to take the controls of a 20 ton excavator we had on hire. I couldn't believe how silky smooth the controls were compared to the smaller machines I had used before.
RNG isn't married, so he can fall in love with an excavator without cheating on anyone - not even his unfaithful Kubota :laughing:
   / Good morning!!!! #93,914
RNG, my neighbor has a land clearing business and has a John Deere tracked skid steer and forestry mulcher head for it. It will go almost anywhere and is very stable but, if working on grass, the tracks can really tear things up. His SS is quite a bit bigger than you're probably looking at but, tracks are not kind to grass when making turns.
Thanks for the warning, Rick. The R4s on the tractor also tear up the ground, especially if it's even a little wet. That's not much of a concern, though, since the fire took out most of the barley/rye/red clover mix I had planted and weeds have taken over. I can see how pivoting on one track while the other is held stationary, or even worse, pivoting in position by reversing the tracks, would really make a mess though. Just like cranking over the steering wheel while in 4WD on the tractor does.
Thinking out loud for a minute, most of my mowing involves running straight up and down the hills, cutting in one direction and then backing up over the freshly cut path to the beginning and moving over one tractor width near the end to setup for the next swath. All this "wasted" motion to avoid getting the tractor sideways on the slope, and to keep from knocking over the uncut grass. It takes more time that way, but it also avoids the sharp turns needed to run around making squares or rectangles. Even so, I've learned to use a sort of three point turn technique to make a right angle turn because it gives me more time to sense if the tractor is gonna tip. I drive beyond the place where I need to end up, back up in a gentle curve until the tractor is perpendicular to the original direction and pointing down the new cutting swath, and then proceed forward. That may help with tracks as well. Going from a steering wheel to a joy stick or a pair of levers is definitely gonna take some getting used to, and I'm willing to accept some collateral damage to the turf (weeds) to avoid going topsy turvee.
When I look back at what I've been using the tractor for over the last year, it's been mainly for mowing. And that's just in the spring for one or two weeks near the end of the growing season if I time it right. The driveway gets graded to fill in ruts and make a smooth path for the motorcycles in the spring, too, then I try to move gravel back onto the steep sections in the fall to help control erosion and improve traction. It also gets a workout moving pallets of firewood into the garage in the winter. And once in a while, I'll use the forks to move something heavy. The tractor was really handy when I first got this place when I was grading around the house and planting a lot of shrubs, but that work is done and won't be needed again until the shop building is completed. But even then, I don't anticipate any hole drilling because I won't be planting any shrubs or trees, not with the new normal need to carefully manage fuels in the areas around the buildings. The other big job for the track loader will be removing all the dead bushes/trees left behind by the fire, most of which are on slopes I wouldn't even try to move a tractor onto. And then grading the root ball craters smooth, again a one time deal (I hope). The track loader also opens up the possibility of clearing a path for a fence on the perimeter of this place, most of which is overgrown with bushes and trees, and all of which is too sloped for a tractor. Bottom line is I think the track loader will get a lot of use over the next few years, but like the tractor, will spend more time sitting still once all those one time jobs are completed.
   / Good morning!!!! #93,915
You know that a new excavator will set you back a few 100 thou.
What is stopping you from buying a slightly used excavator with a thumb?
I'd rent an excavator or a dozer if I needed one, Bill. I don't see any long term need for either, and there's no sense tying up all that money with something that is just gonna sit and depreciate.
   / Good morning!!!! #93,916
Morning Kyle, the unit is from Oklahoma. The Choctaw Nation has a program that helps homeowners that are members of the Nation on the purchase of a storm cellar or safe room. My first option was a safe room that I made myself but Glenda is claustrophobic. We went to Hanauser in Mead where they manufacture a unit that meets the cost of the grant. Glenda stepped in, and out, too small. We went into one this size and she was comfortable so we ordered it. Retail on it is $4,000.00 but with my credit for the dirt work and the grant my cost was $1,150.00. I think the inside measurements are 8 ft X 12 ft with an almost 7 ft ceiling height. The door is spring assisted. It has a vent and a turbine for air. The plan is to install a solar powered system for air circulation and lighting.
Right now we’re living full time in the motorhome while we build our barndominium. We’re doing all the work ourselves, she just turned 75 and I’ll be 71 shortly. Hope you and the family are doing well.
   / Good morning!!!! #93,917
Bike ride to start, had to make trip into town to return title to granddaughter, issues are straightened out.Had to decide to put some more break in time on boat or nap and boat won :)
I think we need to see more pictures of that boat, MG!:thumbsup:
   / Good morning!!!! #93,918
RNG it's also a violation in Texas.
Looks like my car is made and programed to automatically break the law, ohhh no. I think my car's new name is Bandit.
Texas
TRANSPORTATION CODE
TITLE 7. VEHICLES AND TRAFFIC
Sec. 545.406. COASTING. (a) An operator moving on a downgrade may not coast with the gears or transmission of the vehicle in neutral.
(b) An operator of a truck, tractor, or bus moving on a downgrade may not coast with the clutch disengaged.
TRANSPORTATION CODE CHAPTER 545. OPERATION AND MOVEMENT OF VEHICLES
Glad to know that it actually IS a law. Of course I've always known it was dangerous in certain situations. But unless an accident is involved, I'm not sure how the police would enforce it.
   / Good morning!!!! #93,919
I miss boating a lot, but not enough to buy another one at this stage. I do love it though.
Sounds like you need to find a buddy with a boat, Randy. Preferably one that likes to water ski so you get to drive that boat, too!:laughing::thumbsup:
   / Good morning!!!! #93,920
I recommend renting a Tak with a tooth bucket for a week, $1,500.00 be my guess. Most of the machines these days except for the Bobcats are hand controls, intuitive if you致e operated an FEL on a tractor. That way you get to learn what it can do for you. The biggest issue for most people is figuring out how to let the machine do the work.
I work by myself. My first adventure was with a Bobcat helping me handle very heavy wrought iron fence panels in Dallas. First thing that happened was I dropped a panel against the door and I was locked inside. Help removed the panel and I replaced it with Kubota tractor for that job. Then one day I stopped by a JCB dealer and found a skid steer with a door. Life changed.
The Volvo is smoother to use and has more power. One of the tricks I use is when I知 doing something and not moving the bucket I remove the hand from the bucket control. I致e had issues with moving the bucket while concentrating on driving the machine. I was going to start forming up the 3,800 sf slab last week. Weather changed that. Then Tues I went in for a heart cathe and they致e got my right hand on light duty for a couple more days. The cathe was success. We now have proof that I have a great heart for a 70 yr old including the worst plaque build up of forty percent in a couple of places. Excellent for a man my age. So I can still eat my eggs and bacon tacos every morning, sorry Don, genetics.
The plan is form up the pad including the rough plumbing, piers, rebar, etc. Then have a crew handle the pour and finish. I have 2,500 ft of 11 1/2 inch X 3 1/4 inch galvanized 14 and 12 ga C purlins. That痴 the skeleton for the barndominium. I hope to have the place dried in by November when we head west to Yuma for the winter. Hopefully I won稚 need the Volvo after next summer, confine myself to blacksmithing.
Never forget, on TBN if there aren稚 pictures it didn稚 happen
Killbros 375 Gravity Wagon (A50775)
Killbros 375...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox HD-78STD...
