Good morning!!!!
   / Good morning!!!! #93,891
Yep, I heard that "coasting" was illegal when I was a teenager, and it MAY be, but if so, I've never seen such a statute. Can anyone quote such a law?
I also heard that driving barefoot was illegal when I was a teenager, later even knew police officers who thought it was illegal, but no one has ever been able to find such a law, in Texas at least.
RNG it's also a violation in Texas.
Looks like my car is made and programed to automatically break the law, ohhh no. I think my car's new name is Bandit.
Texas
TRANSPORTATION CODE
TITLE 7. VEHICLES AND TRAFFIC
Sec. 545.406. COASTING. (a) An operator moving on a downgrade may not coast with the gears or transmission of the vehicle in neutral.
(b) An operator of a truck, tractor, or bus moving on a downgrade may not coast with the clutch disengaged.
TRANSPORTATION CODE CHAPTER 545. OPERATION AND MOVEMENT OF VEHICLES
   / Good morning!!!! #93,892
There are two kinds of soil here, sandy clay and rock. I was thinkin' I could use the skid steer to start the pad, and when I got down to rock, either rend an excavator or one of those rock hammers for the skid.
Which brings up another question: are the mounts for the various implements pretty much standard? So I could go to the local rental place and check out one of those hammers no matter if I end up with a Volvo, Takeuchie, Bobcat, or whatever brand?
Thanks again for sharing your experience!
Almost all of the attachments will work on any skid steer. Some of the older ones need a little adjustment (cutting torch). But for the most part you can rent a hammer and install it on your machine, performance depends upon your auxiliary hydraulic output. So you would want to have the most machine you can afford. Be a bugger bear to rent a machine needing 25 gpm and all you’re putting is out 11.
However, however the size of a budget or three, when you rent that machine you are corrupting your machine’s oil with whatever and whoever abused said attachment in the past. I’m sure there has to be a process where you can rest something and be confident that the oil in the attachment is clean. This would be a double concern if attachment was something with high gpm requirements. The last guy who rented it had his pumps going south and shedding material and now you have that in your machine. The same concern would be about buying something like a hammer used.
When I was looking for my skid steer I was reintroduced to the reality of skid steers. Most of them are operated by wild things who don’t give a hoot because they belong to someone else. Every now and then you will find an owner operator who has taken care of it but then the price reflects that too.
There are some really good articles out there on the advantages of track vs tires. As Ron mentioned, tracks can have issues in rocks when a rock gets in the mechanism and you lose a track. But in soft sand or mud tires are not competition for tracks. But then tracks tear up turf more than tires. Tracks don’t like hard surfaces, tires don’t either but they’re cheaper to replace. Tires allow a hot dog to wheelie and act the fool, guilty as charged while tracks don’t.
Two kinds of lift, vertical, you lift like a forklift, straight up and down, really nice when loading and unloading with forks or digging post holes. Radial lift, you’re lifting in an arc like with your tractor’s FEL. I’m sure you’ve lifted something with the tractor just over capacity and it was okay until you got it about hood high and then you were going end over apple cart with the rear wheels off the ground, radial lift, hood high, furtherest reach of arc. My first lesson of that was unloading some pipe with the skid steer right after I got it. Bundle of pipe top of the load on the truck. I was able to lift it by tilting back it was so high. I backed up lowering it down and then instantly radial lift kicked in and I was almost bounced out of the tractor as load crashed to the ground. But radial lift gives you best digging mechanical leverage. It is also simpler, fewer arms and pins to maintain.
Once again, for such a pad build I would consider a small dozer. Rent it for a week, keep in mind a weeks is 40 machine hours. They’ll deliver it, pick it up, and it’s as easy to use as the skid steer for first time users. They have joy stick controls and are designed for easy mastery. Beware of renting an excavator. You will fall in love and your life will never be the same. I still get giddy about the time I got to play on a Cat 375, quiet power, unbelievable power.
Here I have iron rock about three foot down for a layer. I use the touch bucket and work at it because I know it is just a layer and it is very brittle, when it breaks it looks like cast iron. The same thing with using the augers, I let it work because I know the material is brittle and will shatter and break up.
   / Good morning!!!! #93,893
I can spell better than that. The same gremlins that turn my apostrophes to gobble gook seem to like changing whole words too. Sorry
   / Good morning!!!! #93,894
I知 part Choctaw and they have a program to help members who live in tornado alley get a storm cellar. We got one that can hold 20 people in a pinch. I saved some money by doing the excavating and back fill.
   / Good morning!!!! #93,895
The unit weighs 21,000 lbs. We hope we never need it. The neighbors understand that it will never have a lock on it even though we winter in Yuma Az.
   / Good morning!!!! #93,896
Texas
TRANSPORTATION CODE
I wouldn't think the function built into the car would put the transmission in neutral does it????
   / Good morning!!!! #93,897
Yes it does!! From section 5-36 page 288 of my owners manual:
"When certain conditions are met, the
engine is automatically decoupled
from the transmission
while the shift
lever is remained in D (Drive). In this
ECO Coasting mode, the engine
stays at idling speed to reduce fuel
consumption and increase coasting
distance. The engine is automatically
coupled back again when ECO
Coasting deactivation conditions are
met. Please refer to ECO Coasting
activation and deactivation conditions"
The conditions for automatic coasting go on to list that the car has to be in Eco mode and in Smart mode, cruise off, the accelerator or brake pedal is not depressed, when going 55km/h to 160 km/h and the road gradient is in the range of -5% to +5%.
There is no engine drag at all and it really just goes and goes. Think soap box derby.
   / Good morning!!!! #93,898
Good evening all. 60F for the start, mostly clear, calm wind. Wind was moderate, sky stayed mostly clear, and high temp was 84F. Bike ride to start, had to make trip into town to return title to granddaughter, issues are straightened out.Had to decide to put some more break in time on boat or nap and boat won :)
RNG, good luck with tractor repairs, and with search for it's replacement, and finish the van.
PJ college buddy of mine worked for spray company while in college. They used helicopters a lot for spraying, especially when spraying forest in the South.
Wrought-Harve good to hear from you.
prayers for all.
   / Good morning!!!! #93,899
while the shift
Oh wow thanks for the info never heard of this before in vehicles!
   / Good morning!!!! #93,900
Was illegal in Maine when I was learning to drive, apparently still is.
LandPride SF2577 Harrow (A53314)
LandPride SF2577...
TRAILER MOUNTED WATER PUMP (A55745)
TRAILER MOUNTED...
VOLVO L70H WHEEL LOADER (A52706)
VOLVO L70H WHEEL...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A55788)
2015 Ram 3500 4x4...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
