Grapple Best Sized Grapple?
/ Best Sized Grapple? #21
Interesting. So if a proper powder coating is damaged, can moisture get in there and start rust, which will then migrate under good, properly applied coating?
I know, I had my Lady Friends rusted winter rims blasted last year, then painted with enamel, and within months, they were rusted and looked terrible. Did my rusted Sierra hitch three times already! The common demoninator is SALT!
/ Best Sized Grapple? #22
The steel will rust at the scratch...nothing can help that...but the water will not get under the coating. As the part continues to rust the metal will scratch will continue to widen but you should not see powder failure until several hundred hours of constant exposure
Here are some steel parts that we tested. You can see how long they were in the salt spray chamber at the top left. Automotive standards are typically 300 hours of exposure. The company we did these for has a 500 hour standard but we ran them until the powder failed. We test aluminum up to 5000 hours
/ Best Sized Grapple? #23
Thanks for the good information. BUT, it's not very comforting. A piece of equipment sitting outside gets almost 9000 hours of exposure in just ONE year!
I wish that companies who makes claims about how great their products are would actually stand behind them.
/ Best Sized Grapple? #24
300 hours in a test booth isn't comparable to 300 hours of typical exposure
I have heard that 100 hrs is equal to one year of actual exposure and that seem about right
/ Best Sized Grapple? #25
That's weird. Like about four days.
/ Best Sized Grapple? #26
I have a 68hp LS tractor that came with a 78" Bucket. I am shopping for a Grapple for it and leaning towards a rock grapple with teeth. I am wondering if I could go 60" or 66" without any problems? I am thinking the narrower beam would give me more maneuverability in the bush. And maybe I'd remove those partially/mostly embedded rocks with less strain on the machine? Thought???
For large rocks I'd personally go with the smallest grapple needed to grab the largest rock my tractor could safely/reasonably lift -- in fact if the work only involved dealing with large rocks (or timbers) a fork grapple or a timber/log grapple (the type with short forks similar to this: GR4 Forestry Grapple for Moving, Loading, Hauling Logs & More! GR4 Forestry Grapple has a maximum grapple opening of 4" ) might even be a consideration.
...actually thinking about it a bit more about the only reason for a wider grapple is to clear large areas or to reduce/remove potential of the front wheels (and possible the back wheels) from running over debris that could cause tire damage. The latter of which is why I went with a 66" EA root grapple for use on my L3560.
Bought a 66" Rock Grapple from MTL Attachments. I Should be able to pick it up on Saturday in Buffalo. Will be anxious to hook it up. It will be the first use of my 3rd function controls. 1[2].jpg
/ Best Sized Grapple? #28
I have a 60" MTL RK5 rock/root grapple. It's not the X series but looks like it would hold up under a 60 hp tractor. It's a little on the heavy side for my 30 hp tractor.
They advertise it as powder coated but the finish wears off readily when used in the dirt. (You know, the stuff you find roots in)
Hate to hijack a thread but if they really do powder coat what are the issues with mig welding?
I have considered buying their 50 single lid unit and welding expanded metal in the spaces to retain small roots and sift dirt.
Hey JD855guy, how have you found the quality of the build? Has it been a good tool for you?
/ Best Sized Grapple? #30
I haven't used it long. Build seems sturdy but the finish comes off easily. No grease fittings on the cylinder pivots. Some gaps and slop on the JD quick connect. I don't like that the tine points don't extend out to the bottom points when closed. Should work great for logs and brush but small stuff falls out. I imagine that would be worse with the wider version unless they made the clamps wider.
/ Best Sized Grapple? #31
Powdercoat will gum up a grinding disc and make your welds look awful with a mig. Not to mention the heat from welding will bubble the paint if it doesn’t get hot enough to set it on fire.
I picked up my 66" MTL X Series Rock Grapple on Saturday. Build quality is very impressive. Swapped out the Pioneer fittings on the 3rd Function remotes with some 1/2" FF connectors last night and got to try my Joystick buttons for the first time. Now if it would stop raining here for more than a day maybe things would dry out and I'd get to really use it. MTL.jpg
/ Best Sized Grapple? #33
I picked up my 66" MTL X Series Rock Grapple on Saturday. Build quality is very impressive. Swapped out the Pioneer fittings on the 3rd Function remotes with some 1/2" FF connectors last night and got to try my Joystick buttons for the first time. Now if it would stop raining here for more than a day maybe things would dry out and I'd get to really use it. View attachment 604674
Congrats on that looks like a very well made piece of equipment. ....also been getting a lot of rain down here too. I know there's that whole saying about April shower's bringing May flowers, but this years has almost been April floods bring the soil so May showers can bring June flowers/gardens. :confused2:
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2007 JOHN DEERE 350D LC EXCAVATOR (A65053)
2007 JOHN DEERE...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
John Deere 185 Hydro Riding Tractor Mower (A66285)
John Deere 185...
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
