L4240HSTC engine oil capacity?
/ L4240HSTC engine oil capacity? #2
Manual says 8.7 quarts with filter for 3940/4240/4740
I added 2 gallons expecting to top it off with more and it was over full.
I removed 16-18 ozs so Im guessing this one is 7.5 qts.
Its a unmolested low hour unit.
Can anyone confirm the amount needed to actually fill your L40 series?
Edit: light came on in my head. This mule belonged to an elderly gentleman and he only used it with a 3pt finish mower. Oil looked pretty dirty. I suspect its s got some sludge build up, OR I just didnt have it hot enough which could account for the discrepancy. I will change the oil again before winter and pay close attention to it.
/ L4240HSTC engine oil capacity? #4
If it’s 4wd and the shaft goes in the middle of the oil pan like the M7040, there a 2 drain plugs on the oil pan. That might be where the oil difference is. First time I serviced the M7040 I drained the first plug and and cleaned the mud off the oil pan and found the second plug. I went and got the book just to make sure cause that was the first 4wd tractor I had ever serviced in 20 years. I also noticed if I do it by the manual, it doesn’t put it on the full mark, it puts it in between add and full.
Yep, pulled both drain plugs. This is my third 4 wheel drive tractor so Im familiar with the two sump oil pans. Im baffled, guess I won’t know until next time I change the oil, unless a 40 series owner chimes in.
/ L4240HSTC engine oil capacity? #6
Ill try to remember to check tonight how much my L3940 takes. Usually i write it in my log. I just bought oil and filters for a change.
/ L4240HSTC engine oil capacity? #7
L4240 Manual states 8.7 quarts with filter change.
After filling it with oil, did you start it, so the filter could fill?
Of course I ran it after changing the oil and filter. Then checked for leaks & shut it down and checked oil level.
/ L4240HSTC engine oil capacity? #9
My notes say i used 7 qts last change for my L3940. I probably topped with a little more, so 7.5 probably about right. Ill know soon, need to change mine.
/ L4240HSTC engine oil capacity? #10
I just changed mine last week, it is a L4240HST (no C). I drained both reservoirs and changed the filter. I put in just shy of 2 gallons to make full. I have 1025 hrs on the tractor which was bought new in '07 or '08.
Mike
Thanks for confirming that the specification for oil fill with filter is off.
My guess after adding 2 gallons and draining some it was 7.5 quarts.
An interesting side note, with it over the full mark on the dipstick on a cold start it would give a puff of blue smoke. When I drained it to the full mark no more blue smoke.
Since I have put 10 hours on it and its been great.
New/Unused Landhonor No Till Seed Drill (A61166)
New/Unused...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2016 KUBOTA SVL95-2S SKID STEER (A62129)
2016 KUBOTA...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A62130)
1987 FORD F-350...
