E170- Bye-Bye Easy Change oil setup
/ E170- Bye-Bye Easy Change oil setup #1
MarkPalmer
John Deere E170, Wheel Horse 867
The more I researched the Easy Change oil system on my new JD E170, the more I realized it's a bad idea, at least for me. It wasn't a selling point when I bought the mower. I understand why they use it, and why some might like it. But only changing out a third of the oil capacity at $40.00 a pop, well, I had to say no to that. I apologize if this has been posted before, but the official John Deere Easy Change delete kit is available here:
John Deere Easy Change Conversion Kit - AUC12916-KIT
The cost of the conversion to standard oil change setup including the 2 quarts of oil and a filter in the kit is $15.00 less than the cost of an Easy Change kit. On she goes. Will not void warranty as it's from John Deere.
-Mark-
/ E170- Bye-Bye Easy Change oil setup #2
Good deal!
/ E170- Bye-Bye Easy Change oil setup #3
I never heard of the EASY Change system so I had to watch a video. Good Grief! I would never buy something like this. It is WAY too "big-box-store-ish".
/ E170- Bye-Bye Easy Change oil setup #4
Prolly for many a person, having no-mess oil changing convenience is ideal.. In this day of "you can't", like get rid of old oil when it ends up in the drain pan, this "Easy-Change" is just the ticket.
But many more of us wouldn't even think about it.
/ E170- Bye-Bye Easy Change oil setup #5
Right... be sure to unplug those spark plug wires before changing oil. We've all been there... having that engine unexpectedly fire itself up right in the middle of an oil change! :-(
I also like how they tell you to "add oil if necessary" after performing the EZ Change oil change. Huh? Doesn't that defeat the "Easy" part for most folks? :)
/ E170- Bye-Bye Easy Change oil setup #6
It has been said that you can sell a turd if you polish it. That thing should win the polished turd award.
/ E170- Bye-Bye Easy Change oil setup #7
Suspect the "add oil" if necessary, is for an engine that uses or "burns" some oil.
It's a gimmick.. that just may be what helps sell some more Deere lawn tractors... works for me.. :D
Will make some of the non-Deere people more green with envy.. ;)
/ E170- Bye-Bye Easy Change oil setup #8
Adding oil as needed on the top side is easier than draining it from underneath the machine.
Besides, you're going to periodically replace any oil that is burnt during operation.
It will be interesting to see if this "feature" continues for any length of time.
Most if not all of these engines have drains on the side. A lot of them now days don't even require tools as the drain tube just has a screw-on cap. It can still be a little messy changing the filter. I know some of these small engines can burn oil but I guess I've been pretty lucky. I've had three different JD tractors with Kawasaki engines and a Ariens with a B&S engine and I never needed to add a drop to any of them. Heck, I even run 5W-30 synthetic in the Ariens during the summer and it never burns a drop.
/ E170- Bye-Bye Easy Change oil setup #9
So what does one do with an old oil filter full of oil?
I think JD wants you to drop off the old filter at the dealer. Which can be a PITA depending on how close your dealer is.
/ E170- Bye-Bye Easy Change oil setup #10
I'm just thinking that this convenient sealed container of waste oil will make its way to the landfills more often than not. I sure hope it doesn't though.
This has been another issue users are having with it. From what I have gathered, you have to add quite a bit of oil, up to half a quart, when switching out the Easy Change filter. So not only $40.00 for the Easy Change kit, but the cost of a quart of oil on top of it. I think Popular Science was awarding this system without understanding that it really does next to nothing advantageous except avoid a little bit of mess. A previous post was right- most of these easy Change filters will just end up in the trash, giving it another thumbs down.
-Mark-
(10 Bundles) Standing Seam Metal Roofing (A61166)
(10 Bundles)...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2002 Godfrey Sweetwater Pontoon Boat (A61166)
2002 Godfrey...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
1770 (A58375)
1770 (A58375)
