radioman
Super Member
My BX24 60 inch mower deck had a couple bolts stripped and spindles threads was ruined. I think i got a little overzealous :ashamed: with the air impact when tightening them since last summer the blades were spinning and not cutting from one of them. I had a bear of a time trying to take them off last weekend when i was about to take blades off to sharpen them. I was able to get the bolts off by reversing/forward many time to get the stripped threads loose enough to back bolt out- but i was nervous about needing a new shaft and rebuild the spindles. Since the dealers were closed over the weekend, i waited till monday to pick up new bolts and yesterday finally worked on it. i had to retap the spindles and if anyone needs to know what tap you need its M12 - 1.25 . got one spindle cleaned easily - but the middle spindle was a bear. took me over an hour to tap it. it must be high speed steel or something as it was really hard to run new thread. used whole quirt can of oil and i was nervous about breaking the tap as it was really twisting as i was turning it when trying to go a tiny 1mm of a turn or so. i had several pieces of metal fragments come out as i air cleaned it out - but it was finally done and i was able to test mow it last night at 9pm jand so far so good
So - lesson learned - if the blades werent holding anymore and not cutting right - its possible the bolts were either worn out or stripped and threads is trashed a little. this time I hand tighten them instead of using impact. Ill still use impact to take them out , but will always hand tighten the bolts.
