Lessons on strapping down a tractor
/ Lessons on strapping down a tractor #1
artho45
Central Nebraska
Kubota. L2800
I think we could all take lessons from this guy on how to strap down a tractor. Don't know any details, just saw it on the internet.
/ Lessons on strapping down a tractor #2
I think the lesson should be how to connect your trailer to your truck.
The tractor looks tied down well.
/ Lessons on strapping down a tractor #3
Don't take lessons from this guy quite yet. Sounds and looks like he didn't have enough tongue weight. He strapped it down very well, but at the wrong spot on the trailer:
/ Lessons on strapping down a tractor #5
He tied it down very well and it looks like the ROPS held up. Lesson hopefully learned on proper trailer loading.
You see a lot of tractors driven onto a trailer, should he have backed it on? That or have the loader bucket over the front would be the only way to get more weight forward. Or of course he might have the wrong size trailer too.
/ Lessons on strapping down a tractor #7
I don't know what caused him to lose it, maybe hitch failure but it looks like tandem axle trailer and "center" of tractor seems to be over the axles which makes me think with FEL weight distribution should have been forward....
Funny this should come up today, because tomorrow I am going to load my SCUT on a tandem axle trailer(16 ft car carrier) for first time to take it to dealer for service....
Guess only real way to check weight distribution is measure hitch height of truck/trailer with out trailer loaded and then with trailer loaded, if I get some down measurement at hitch I would guess I have tongue weight...
Dale
/ Lessons on strapping down a tractor #8
Anybody notice the difference in the two pics of the tractor&trailer?
1 tire showing on trailer
602875d1556714310-lessons-strapping-down-tractor-trailer-jpg
no tires on trailer
602872d1556712608-lessons-strapping-down-tractor-59211521_2419710624728591_4448401626805305344_n-jpg
Perhaps he had a blowout and it started whipping.
I lost a wheel of a UHaul once and it started whipping. But my loaded dually barely noticed it.
/ Lessons on strapping down a tractor #9
no tires on trailer
Look again rear tire is on trailer, badly bent rim it appears though.... Got to wonder if front tire and rim were ripped off lug bolts during incident or it was a case of stupid and towing without wheel and tire on front (yes seen it)...
Only difference in pictures is camera angle....
Dale
/ Lessons on strapping down a tractor #10
Those are different pictures, different cop car, different truck.
/ Lessons on strapping down a tractor #11
Parallel Universe!
Kind of pointless to make assumptions. To me, the fact that it detached from the tow vehicle is the scary part. Seeing some of the chains and hitch arrangements on utility trailers, you wonder if it's just for show, but legal. Some look more suitable for tying up a poodle. I have heard of rating on tie down chains and straps, but NEVER on safety chains. It doesn't surprise me though.
/ Lessons on strapping down a tractor #12
Idiots and their whipping trailers......shame people have to die from simple mistakes.
/ Lessons on strapping down a tractor #13
Dale
Compare
Bruce
/ Lessons on strapping down a tractor #14
Had to be one wild ride :eek: glad driver okay whew.
/ Lessons on strapping down a tractor #15
Multiple pictures from different angles. The white truck may be a witness. The silver truck appears to be off the road, down the embankment. Not unusual for two SO units to be on scene, one on each side of the center median.
Do we know where this happened?
/ Lessons on strapping down a tractor #16
I've seen bearings seized up on a trailer to cause it to whip. There is more than enough weight on that trailer to keep it from whipping. That youtube video of the weight distribution is misleading. It transfers weight from the front to the back, but it ignores all the weight over the axles. Having weight on the axles does not cause that violent whipping.
Good job on tying it down
Bad job on keeping the bearings greased.
/ Lessons on strapping down a tractor #17
Funny, how in a world where so many bearings become maintenance free, that trailers still require this attention.
/ Lessons on strapping down a tractor #18
This trailer with the skid steer had "enough" weight but was there enough tongue weight? As bad as the whip was...he did a good save.
/ Lessons on strapping down a tractor #19
The tractor could have easily been mounted farther to the rear of the trailer prior to the calamity. Hard to tell if it's strapped or wedged in place by the bucket against the front rail. Glad the driver is OK - bet his shorts are trash....
/ Lessons on strapping down a tractor #20
Dale
Guessing tongue weight is not the best idea.
If you go to the etrailer website, you will see a method for measuring tongue weight using a bathroom scale.
The maximum weight capability of the bathroom scale does not matter.
I use this method with my 14K equipment trailer, to get at least 1400 lbs tongue weight.
It's not necessary to do the procedure every time, if you are carrying a similar load.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
Bell 1600 Gallon Nurse Trailer (A63118)
Bell 1600 Gallon...
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
74 Gallon Delta Fuel Cell with Tool Box (A61166)
74 Gallon Delta...
Hustler Super Z 60in. Zero Turn Commercial Mower (A61567)
Hustler Super Z...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
