Chilliwack Murray
Gold Member
Those were incredibly tough trailers. I had (have) a 5x10 that I got used about 20 years ago and made many trips that could’ve been posted here. Used it for two moves (everything I own is heavy), brought home all the lumber to build My previous shop, numerous loads of sand and gravel that were probably 2-1/2 times the rated 1000lb capacity. It was quite amazing what that trailer could carry compared to its empty weight. Those were different days and I often didn’t have two nickels to rub together so you make do with what you have. It’s also the trailer that I drag around behind the Kubota when I’m working in the yard.
A couple years ago a wheel bearing went and I didn’t notice it right away and needed an axle. I ended up buying a 3500lb axle and springs, doubling up the frame and adding some better crossmembers and vee braces to the tongue. Changed the reg to 3500 lbs and have had much more than that it in. Kept the sides and the ramp.
It still amazes me what that trailer could take vs its weight.
