Rounded off drain plug
/ Rounded off drain plug #1,621
Back to Kandos's basic problem: He never mentioned his welding skills or outside resource for such as far as I can remember. In my pipe fitting days we occasionally encountered fittings that just would not bulge, short of collapsing totally, no matter what we tried. Solution: Drill out to inside diameter size, get a forged steel coupling size to fit over the existing and cut it in half, set over the existing and weld all around, ala, new drain hole. Due to the thinness of an oil pan O/A or TIG the weld method of choice.
Ron
/ Rounded off drain plug #1,622
Ron
IIRC it’s a tranny case so thinness shouldn’t be a prob. But I’m not familiar with his tractor...
/ Rounded off drain plug #1,623
I wonder if Kando was able to remove the round bar that was hindering access to the plug? He posted a pic early on and said he thought it could be removed. If not, it looks and any drilling or tapping into the hole would be difficult at best.
/ Rounded off drain plug #1,624
Welding; cut the bar out and then weld it back, easy stuff.
Ron
/ Rounded off drain plug #1,625
Ron
Would not be easy for me laying on my back, trying to weld it :eek:.
/ Rounded off drain plug #1,626
Thanks for reposting that pic Xfaxman.
Looks like a cast pan with reinforced boss for the female thread.
I’ll stand by my original suggestion of HEAT the PLUG quickly and twist off with pipe wrench or almost any of the other gripping tools suggested multiple times.
/ Rounded off drain plug #1,628
If I lived near him, I might sneak over, remove plug, replace with new one... of course I would have to replace fluid so he didn't run it and damage something due to low fluid.
/ Rounded off drain plug #1,629
Just an update on Holiday Inn Express, so far no reports of Kando staying there
/ Rounded off drain plug #1,630
You check under N.O. Kando?
/ Rounded off drain plug #1,637
/ Rounded off drain plug #1,639
/ Rounded off drain plug #1,640
Once again, I've been introduced to a new tool on this thread.
Now I'm not going to rush out and purchase one for myself (like I did for my Knipex), but I have the knowledge that it exists. :thumbsup:
Yes but you have to admit the one I posted would be more FUN.
Especially on those occasions when your BIL asks “ Got a light?”
Hustler Super Z 60in. Zero Turn Commercial Mower (A61567)
Hustler Super Z...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
(2) UNUSED 16X7.50-8 TIRES W/4 LUG RIMS (A62130)
(2) UNUSED...
2010 Dodge Charger Sedan (A61569)
2010 Dodge Charger...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63118)
FRESHLY...
2012 Volkswagen Passat Passenger Car, VIN # 1VWBH7A33CC033108 (A61165)
2012 Volkswagen...
