I need some advice on how to rig a horizontal tree to pull it sideways 30'
   / I need some advice on how to rig a horizontal tree to pull it sideways 30'
More info needed...
How close can you get the jeep?
How much cable does the winch have?
How far from where the tree is to where you want it?
Is there a big enough tree back there to hook one of your pulleys on?
About 80' to the driveway and I can set the Jeep there BUT there is no place to anchor it.
Winch has 80' of cable.
30' to where I want it.
There are three trees I can hook up to.
I need to correct myself, the rope is 5/8" not 3/8.
The crotch is right at my head height and I am 6'4" tall.
It was rotten on the inside.
At the pace that spring is arriving, I wont be able to get on that yard until next fall when I come back from my summer work.
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #23
30+" diameter hung 6' off the ground?
Nuh-uh. Not me.
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #24
I wouldn't cut that stump without at least a polesaw...
That looks like its just waiting to spring loose and land on someone...
Aaron Z
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #25
make the first cut up above the butt shatter,cut the limbs off one side if you want so that the tree will roll toward the unsupported side.
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #26
Ok..... I've got a LOT more time then money and I like the challenge.
As I already suggested, park another vehicle behind the jeep to help anchor it.
Secure double pulley to tree line where you want tree.
Run rope through pulley to single pulley hooked to tree you want moved, and back through double and secure to single pulley.
Hook other end to winch.
This will give you a 3 to 1 mechanical advantage. Easier on the jeep & the rope.
Cut the tree into 15'+/- sections & pull.
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #27
Also beware that even a 5/8" rope will stretch and become one big elastic and watch out should it snap!
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #28
You could use the rope to rig guys or "preventers" to stabilize the trunk somewhat near the stump. There is a lot of energy stored in the compressed limbs. I suggest attacking the split/break with an axe. An axe because the notches won't bind like a saw kerf, the process is fairly slow so forces would be released slowly, you will already have an arm's length plus axe handle head start down your escape route when it starts to move.
Once free of the stump the trunk may settle some. I would start limbing and bucking from the tree top. Take your time to analyze the forces involved. Be safe.
It IS going to be a challenge.
   / I need some advice on how to rig a horizontal tree to pull it sideways 30' #30
Surprised no one has mentioned the obvious. Looking has no where near the proper equipment or expertise to move that thing whole. Cannot imagine any one bringing in such equipment to tackle one tree. Each 20' section, minus branches, weighs as much as his jeep. Cut it up in manageable pieces as most have said. Always start at the tree top and work back. Only cut branches as you move down the tree that support the section being cut. As you remove the outboard weight, the tension in the fractured stump will lessen, and reduce danger of a pop up. I have done a couple of those successfully. Looking, what is our hurry to get it moved?
Ron
CLUBCAR GAS GOLF CART (A54756)
CLUBCAR GAS GOLF...
UNUSED (1) 3500# AXLE W/ BRAKES (A54756)
UNUSED (1) 3500#...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2014 Vermeer BC1000XL S/A Towable Chipper (A55787)
2014 Vermeer...
Year: 2006 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 86,950 Plate: Body Type: 4 (A55788)
Year: 2006 Make...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
