Modding a ground clamp?
/ Modding a ground clamp?
Yopu need to address this on a welding forum.....
Experience of 38 year of working with power cable and such, get proper size lug, meaning hole for bolt and for cable size, If you don't have proper tools go to good welding supply and they should have repair lugs and proper crimpers....Any place that sells bulk welding cable should have proper lug... Even Tractor Supply...
This close to what you need
Thomas & Betts - 5415 - Lug; One Hole; 1/4"; Blue; 6 AWG; .53" Lug Sz; 1.23" Overall L; .44" W; .31" Cable Sz - Allied Electronics & Automation
Or
Thomas & Betts - 5413 - Copper One-Hole Lug; #8 AWG; 1/4" Bolt Size; Die Code 21; Color Code Red - Allied Electronics & Automation
IF neither of these are correct tell me exact size of cable and hole size you need I can supply information on proper lug...
Sorry, didn't know you lived in a bubble....
Dale
Those don't work. But I think I found it... 4 gauge wire and a 7/16in stud.
4 AWG, 1/2" Stud, Tinned Copper, Crimp or Soldered
A 5 pack for $5.20. Funny thing is that ElectricalHub is a distributor for my company! I think I will pay them a visit and ask for a sample!
/ Modding a ground clamp? #23
A piece of copper pipe, hacksaw, hammer and drill and make your own. Custom sized to fit.
Or: hacksaw a slot on the existing terminal, crimp in the wire and fill with soder.
/ Modding a ground clamp? #24
/ Modding a ground clamp? #25
Crimping (properly at least) is superior to soldering. As odd as it sounds it's quite true. When you solder stranded wire solder wicks up the strands & fuses them solid. You then end up with flexibility issues. Chances of damaging insulation is high as well. In the event of any issues, wiring heats up. That doesnt phase crimps much, but soldered connections can fail catastrophically in those situations.
All car & aircraft wiring harnesses are crimped. If you have the right crimper an idiot can get a good crimp that can easily be inspected. Soldering takes skill & in blind lugs like you are talking about they cant be inspected.
There are dozens of cheap hydraulic crimpers out there. Goplus 16 Ton Hydraulic Wire Crimper Battery Cable Lug Terminal Crimping Tool w/ 11 Dies https://www.amazon.com/dp/B00ZA2P3XM/ref=cm_sw_r_cp_apa_i_h2iWCbYH1SJN6 is a random one off Amazon. I'm sure its identical to the others there or the one from Harbor Freight. I picked up on off Amazon for a pile of big Anderson connectors. Its a cheap tool & a little fiddly to use, but great bang for the buck.
I'm sure you could make soldering work, lots of people have, but it's an inferior technique for most modern applications.
Also, get the right sized lug for your wire & terminal. You can use a copper pipe as a shim or fold over the wire, but that severely weakens the connection.
Okay for you guys that were worried I was going to have a half-azzed end product... rest easy. I decided to visit my distributor that I do business with and they happen to be industrial electrical parts business. He gave me a few samples of the proper terminal... a 1/2in dia. 6 gauge. I brought in my cable and went back in the warehouse and he let me try out a $240 crimper and a cool wire stripper with depth gauge that works like a thin wall pipe cutter.
Power Lug Terminal Crimping Tool
He also gave me a bunch of shrink wrap various sizes for my collection of misc electrical stuff. When I got back to my shop, I used a bit to finish off the connection along with the other existing end.
Job finished. Reinstalled the ground inside the welder and attached the Magswitch. I'm happy... just have to get this by the TBN QA department! :D
/ Modding a ground clamp? #27
Nice work. I use both regular and Mag grounds. I have quick disconnects 5' from the clamp so i can switch between Magnetic and Aluminum/Stainless
I was thinking about that! Now I am only set up to do mild steel but I do have a spool gun for my MIG that I have yet to use. Probably end up selling that and go with a dedicated TIG if I get serious.
What do your quick disconnects look like? Part no's? Didn't know such an animal exists but it doesn't surprise me.
/ Modding a ground clamp? #29
I will thinking about that! Now I am only set up to do mild steel but I do have a spool gun for my MIG that I have yet to use. Probably end up selling that and go with a dedicated TIG if I get serious.
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
1996 GREAT DANE TRAILER 48X96 SPREAD AXLE FLATBED (A60736)
1996 GREAT DANE...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2010 GENIE GR-20 VERTICAL MAST LIFT (A59823)
2010 GENIE GR-20...
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
