How many hours do you have on your tractor
/ How many hours do you have on your tractor #21
I'm at 178 hours on my L3400. Bought March 2009. Might I say, its not heavily used?
/ How many hours do you have on your tractor #22
My B2650 was bought new in January 2016 and now has 410 hours. Much of that was renovating an old orchard and landscaping a new house. Pretty much I would figure 60 to 80 hours a year from now on.
/ How many hours do you have on your tractor #23
just a technicality for recorded hrs on tractors with mechanical rpm hr meter. usually on those, 1 recorded hr on engine= 1 hr @ 550 pto engine rpm which is usually around 2250 engine rpm.
so actually there can be more "engine hrs" on a tractor than recorded when engine rpm falls below 2250 or so on those mechanically linked rpm/hr meters
know this may be a mute point, but can come into play for example when considering purchasing a rental with lots of low or idle rpm conditions. just something to consider......
/ How many hours do you have on your tractor #24
My 2004, JD4310 is the first tractor I've owned that had a working hour meter. It is reading 1280 right now. There is no way to know if it has been replaced. I plan to check it for accuracy one of these days. I noticed after mowing the other day I had put two hours on the meter. I have been writing the hours on a piece of tape and sticking it on the dash because the fuel gauge isn't accurate. I have calculated fuel use to be around .7 GPH by the hour meter.
My former little tractor, a JD855, had an hour meter that stopped working at 2300 hours. I ran it 5+ years and sold it with no apparent degradation in it's performance. I didn't log my time using it and have no idea how many hours I put on it. There is no telling how many hours it ran after the meter quit before I bought it.
I bought my NH 575E off ebay and the seller told me it had 3000 hours on it. When it arrived it had the glass broken on the meter and obvious signs the thousand hour numeral had been pried down to read 3xxx. Of course it no longer worked after the damage I assume the seller inflicted on it. I ended up working on it for several weeks before it would stay running to do any work with. BUT the engine runs fine and doesn't use much if any oil. It's a 99 that began life as a municipal owned unit so I'm betting it had over 5000 hours.
My 2011 BX has 1500 hours on it. Still runs and works as good as when new. Have spent $0 on major repairs, most minor stuff I do my self. Age is showing in damages to plastic parts. It sets outside all the time so oxidation of paint is there. It will probably take $500 in misc small parts to correct appearance items and a couple electrical glitches that do not affect functionality.
Two years ago tried to sell it. Many inquires but as soon as they learned Hrs on it no one was interested any more no matter the price. I have a few more outside projects for it at our current place and then will not need it any more. Will probably have to virtually give it away. Seems the SCUT used market is centered on <500 HRs, based on comments I read here and elsewhere.
Ron
I'm pretty sure someone would buy it with those hours and more, someone like myself wouldn't think that is alot of hours, seems low to me.
/ How many hours do you have on your tractor #26
Ron
1500 hrs would not bother me if the machine was cared for. It has a lot of like left in it.
/ How many hours do you have on your tractor #27
The hours wouldn't bother me.
The setting outside all the time is what would bring the value way down if I was buying..
/ How many hours do you have on your tractor #28
I have 325 hrs on mine. I am around 100 hr per year user apparently.
/ How many hours do you have on your tractor #29
Mine has around 1200 on it. Runs great and appearance is a little rough but appearance isn't the reason I bought it.
/ How many hours do you have on your tractor #30
BX2200 has about 950 on it. I have several acres to mow, and use this one for mowing with a belly mower. No major repairs.
B7410 has just over 300 on it. It had just under a hundred when I bought it a little over two years ago. I use it with the rotary mower, disk, and tiller. I've priced adding a loader to it, and as soon as I get a couple of more important things out of the way, I'm going to have it installed.
/ How many hours do you have on your tractor #31
My Kioti DK 35 has 2165 hours.
Still working like new.
/ How many hours do you have on your tractor #32
Hours?
How about years?
Of all of our tractors, our 1942 Ford 2N runs the most hours due mainly to mowing.
77 years later, I can mount a mower on any tractor I want, but just love our old Ford.
MAINTENANCE is the key!
/ How many hours do you have on your tractor #33
My B6200 is doing great, only 81 hours on it. Not so long ago it was 900 and some. At this rate it's gonna be new again soon.
/ How many hours do you have on your tractor #35
1993 Ford 4630, 1,097 hours. Only tractor with an hour meter.
/ How many hours do you have on your tractor #36
Got mine in the fall of 2017. Just turned 830 hours. Work it hard most of the time. First 400 hours was FEL use, last 400 hours is FEL, 3 pt and PTO use.
Purrs like a kitten, works like a mule.
And the gentleman before me, that said "maintenance" was the key....ditto!
/ How many hours do you have on your tractor #38
I needed (wanted) a 15' flexwing mower to cut the fields. Found a (beat up) one for pretty cheap dollars so bought it.
Trouble is, I now needed a tractor to pull it!!!!
Stumbled across a 1973 International 1066 with 3,688 hours on it. (125 hp at PTO according to Tractor Data)
Tractor has some surface rust/issues but is really very straight for something that is around 46 years old!!! So I jumped on it and indeed, the engine is strong as a mule!!!
Need to fix some other issues but I knew those walking into it. Just yesterday, bought a can of International Red so I can put a new coat on most of it.
/ How many hours do you have on your tractor #39
Very clever...like it ! :yes:
You like that? I got something to top it! I just got back from the dealer, where I bought a new tractor! And traded in my old one. So now my tractor has 15. It really IS getting younger! Besides that, it's blue, instead of the traditional Kubota brown. I guess Kubota is officially orange, but my old one was about 51% brown. Today is a pretty happy day!
/ How many hours do you have on your tractor #40
Without pics it never happened. :D
2014 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61568)
2014 Chevrolet...
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
INOP/NON-RUNNING 1998 International 4900 Cab/Chassis Truck, VIN # 1HTSDAAL5WH539755 (A61165)
INOP/NON-RUNNING...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
