Cultipacker
/ Cultipacker #1
AllDodge
S, Central, KY
Terramite T5C, Kubota M9540HDC24, F3990, RTV1100, Cat 416C, D3B, 955L
What is better, single or double row cultipacker?
My tractor is 7ft wide, and assume need at least that wide and maybe more. Finding many on craigslist, but as with all used stuff there can be issues.
Any wisdom when looking at used stuff?
/ Cultipacker #2
What's better?
What's better by far, is a "crow foot" cultipacker... After that, just get one that "at least" covers your tire tracks.
SR
/ Cultipacker
Will look for crow foot tx
Anything to watch for with used stuff?
/ Cultipacker #4
Bought an old 8ft dunham last year . It still has the old wood bushings, it is a single row and it worked great on my food plots , i might try to put some real bearings on it this yr. There is a guy close to me who rebuilds old ones and sells them.
/ Cultipacker #5
I have an old John Deere 12 foot two row cultimulcher (cultipacker with clodbusters between the rows). Use it behind the disc for smoothing and experimenting with it right now for terminating cover crops to plant into them (run over them the first time to flatten them and then at 90 degrees to crimp and terminate the stalks).
/ Cultipacker
I'll be ordering a bush hog 3D96 disc harrow so I'm thinking about what to use afterwards
/ Cultipacker #7
what are you planting and why.
/ Cultipacker
Only grass for now. Have ripped up a bunch on trash trees and other crud. Going to be ripping up more with track loader. Have fields with ruts from heavy equipment, chicken house and other things. Plan to use disc to help smooth it out, then pack, then seed
/ Cultipacker #9
any old heavy cultipacker will work fine.
/ Cultipacker #10
I bought a 7 foot Brillion one row. I was disappointed in its performance. With our heavy clay it wasn’t heavy enough to break up clods. I would get a double row if possible, and as heavy as you can find.
/ Cultipacker
Good point
/ Cultipacker #12
We have a 7' from EA (the bigger version, IIRC) and pull it with a MF 1533 (just got a 5065e that we will pull with it, too, I'm sure) and it's awesome.
/ Cultipacker #15
Bullbreaker,
Just curious here. Did you go to Montana to ride a bull? Your location is listed to the left as Florida.
No i have freinds out there , visit when I can and check out the CL farm listings . Also check out the Maine CL frequently also . I 'am in eastern Collier County ,Fla 34117 .
/ Cultipacker #16
Thanks for satisfying my curiosity. BTW, I meant to remove my first question when I thought of a better way to word it.
2016 Yamaha Wave Runner VX (A61165)
2016 Yamaha Wave...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A62129)
2023 HANGCHA...
(10) 36' HEAVY DUTY INSULATED PANELS (A62131)
(10) 36' HEAVY...
2018 BOBCAT S470 SKID STEER (A62129)
2018 BOBCAT S470...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
