HERE SHE IS-FINALLY
/ HERE SHE IS-FINALLY #1
eubie5
Gold Member
Greenville Indiana (southern Indiana)
kubota bx2380
it was official yesterday, signed everything yesterday morning and my baby was delivered yesterday afternoon. They forgot the grapple(how do you forget a big implement?), and brought that this morning.
It's been pouring rain the last couple days, but during a break, i took her out and got a little mud on the tires.
Can't wait for things to dry out. 20190420_172756.jpeg20190420_172741.jpeg20190420_172733.jpeg20190420_172724.jpeg20190420_172716.jpeg20190419_151402.jpeg
/ HERE SHE IS-FINALLY #3
Congratulations... looks great! What are you going to use on the rear? Probably want some ballast at least and I see you have a 3pt hitch! :thumbsup:
Before i do any real loader work, i plan on making a homemade concrete ballast. Probably use a 30 gallon barrel i have, or part of it, to make it. That will be plenty of weight. Plus, i have a box blade and a 5ft blade for the back.
/ HERE SHE IS-FINALLY #5
Sounds like a plan! I have a box blade and rear blade for my BX. Bought a DIY kit to add hydraulic top and tilt adjustment for my blades. Just need the time to get the project done.
/ HERE SHE IS-FINALLY #7
/ HERE SHE IS-FINALLY #8
Be very, VERY careful. There have been a few threads here recently about people bending their curl cylinders and it seems to be not uncommon with grapples.
Isn't that standard?
/ HERE SHE IS-FINALLY #9
Congrats :thumbsup: your project list just got a whole lot easier. :)
/ HERE SHE IS-FINALLY #10
:thumbsup::thumbsup::cool2:CONGRATULATIONS!!!!!!!! You will probably never get around to messing with the concrete home made (I did a home made concrete for the front of a small B2320 once). With the BB which you can leave on all the time except when you may use the blade or other 3ph attachment you'll have all the weight you need and if not enough weight put some concrete blocks on the BB. I always leave my BB on unless I'm using one of the other 3ph attachments.
/ HERE SHE IS-FINALLY #11
Very nice setup. Is that the old mower out in the yard in the background :)
/ HERE SHE IS-FINALLY #13
Congratulations, nice looking setup to handle the equally nice looking home and property. Love my kubotas. They are reliable and make life easier.
/ HERE SHE IS-FINALLY #17
how would that damage happen? trying to lift too much with grapple?
Generally you can damage the curl cylinders by back dragging at high bucket angles. The lines are closed & back dragging generates excessive force. If you are actuating the curl cylinders, the relief valve is in the circuit & should protect things.
/ HERE SHE IS-FINALLY #20
To be honest, I can't remember. I bought a BX25D that came with a backhoe attached. I'm not sure if the 3pt was optional or not.
The 3ph arms are not standard on the BX25. Some dealers add options like 3ph arms on BX25s and don't mention it to the customer but the charge is usually there since they have to pay for them.
207280 (A52708)
207280 (A52708)
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
84in. Fork Extensions (A61567)
84in. Fork...
NEW HOLLAND LB75B BACKHOE (A62129)
NEW HOLLAND LB75B...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
