2012 Kubota BX2660
/ 2012 Kubota BX2660 #1
HunterKioti
Member
Coloma, Michigan
Massey Ferguson GC2300
I've been looking for the past few months at tractors and Sub Compacts, I finally found what I think is a good enough deal to pull the trigger on. I'm looking at a 2012 Kubota BX2660 with a loader and 60 inch belly mower with 50 hours for $11,000. From what I've found that is a very good price around me. My main questions are does anyone have this tractor, and if so how did you like it? I've already read a bunch about being careful with the transmission cooler being exposed. More importantly how does this machine perform dragging/loading decent size logs, nothing crazy. Moving snow, finish mowing without turf tires, moving dirt and gravel, maintaining driveway with box blade. Does anyone have real world experience with the loader capacity? I appreciate any input you have! Thank you, and I hope to be a Kubota guy soon.
/ 2012 Kubota BX2660 #2
You want a subcompact for dragging logs???? Around here "decent size" is when you have to cut from both sides with a 24" bar.
If you really want to pull logs I suggest a compact and a lawn tractor/riding mower for the lawn.
Yea, my decent size are cut down with a 16" saw. I don't have anything of size, mainly just smaller pines.
Enlighten me, last thing I want is to be unhappy with my purchase. I only have 7 acres, I do all my work by hand right now so anything will be better than that. Where do you think the Subcompact would come up short?
/ 2012 Kubota BX2660 #6
Kubota BX2660
2008 - 2013 BX60 Series
Subcompact Utility tractor
Next model: Kubota BX2670
Manufacturer: Kubota
Original price (USD)
$11,736 (2009 )
$12,136 (2011 )
$12,484 (2013 )
Kubota BX2660 Engine:
Kubota 1.0L 3-cyl diesel
Bore/Stroke: 3.00x2.90 inches [76 x 74 mm]
Power (gross): 25.5 hp [19.0 kW]
Rated RPM: 3200
Starter volts: 12
Oil capacity: 3.3 qts [3.1 L]
Coolant capacity: 2.8 qts [2.6 L]
Capacity:
Fuel: 6.6 gal [25.0 L]
Hydraulic system: 3.1 gal [11.7 L]
3-Point Hitch:
Rear Type: 1
Rear lift (at ends): 1,210 lbs [548 kg]
Rear lift (at 24"/610mm): 670 lbs [303 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@3120
Mid PTO: independent
Mid RPM: 2500
Engine RPM: 2500@3043
Dimensions:
Weight: 1,389 lbs [630 kg]
Wheelbase: 55.1 inches [139 cm]
Length: 95.5 inches [242 cm]
Width: 44.5 inches [113 cm]
Height (ROPS): 70.4 inches [178 cm]
Ground Clearance (front axle): 8.7 inches [22 cm]
Front tread: 36.6 inches [92 cm]
Rear tread: 32.2 inches [81 cm]
4WD turn radius: 7.2 feet [2.2 m]
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: rear standard
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post fixed ROPS. Canopy optional.
Loader:
Loader type: Kubota LA243
Height (to pin): 71.3 inches [181 cm]
Clearance, dumped bucket: 52.4 inches [133 cm]
Dump reach: 28.9 inches [73 cm]
Dump angle: 45
Rollback angle: 29
Breakout force (lift): 992 lbs [449 kg]
Lift to full height (at pin): 745 lbs [337 kg]
Lift to full height (at 500mm): 518 lbs [234 kg]
Bucket capacity: 0.18 cu yd [0.1 cu m]
Bucket width: 48 inches [121 cm]
Hydraulics:
Type: open center
Capacity: 3.1 gal [11.7 L]
Total flow: 6.3 gpm [23.8 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Battery:
Number: 1
Cold-cranking amps: 535
Volts: 12
Page information:
Last update: April 17, 2013
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
/ 2012 Kubota BX2660 #7
I'm looking at a 2012 Kubota BX2660 with a loader and 60 inch belly mower with 50 hours for $11,000. From what I've found that is a very good price around me. Who has this tractor, and how did you like it? I've already read a bunch about being careful with the transmission cooler being exposed. More importantly how does this machine perform dragging/loading decent size logs, nothing crazy. Moving snow, finish mowing without turf tires, moving dirt and gravel, maintaining driveway with box blade. Does anyone have real world experience with the loader capacity?
I have 7 acres, I do all my work by hand right now so anything will be better than that. Where do you think the Subcompact would come up short?
BX series tractor are best regarded as wonderful lawn mowers with the ability to do light landscaping tasks. Kubota sells bazillions of BX tractors yearly and many owners are completely happy with them.
With only 9" ground clearance with mower removed, it is difficult to take a BX into woodlands. Because of low ground clearance, HST cooling fan under the tractor is vulnerable to ground damage. Those who take BX tractors into woodlands often armor underneath. Several venders sell armor kits.
Removing/replacing a Mid Mount Mower, with its front PTO shaft, is a tedious, sweaty task.
VENDER: BXpanded Under Armor
FEL bucket lift capacity is around 500 pounds. Not much by tractor standards BUT SURE BEATS TRUNDLING A WHEELBARROW OF 80 POUNDS CAPACITY. Tractor is 1,389 pounds bare tractor. With a full bucket, the tractor can be a bit unstable.....but so are other tractors. Front axle is thin. Plan to keep 350 to 450 pounds counterbalance mounted on the Three Point Hitch when doing Loader work. Weight behind the robust rear axle unloads weight from the relatively weak front axle.
The three reasons owner/operators trade up from a BX:
More tractor weight.
More FEL lift capacity.
Greater ground clearance
The BX tractors are solid for what they are. Excellent first tractors. Easy to service yourself.
If mowing is your primary task you may be happy for years. BX will do your other tasks but will be somewhat slow. (Allowing for 5" overlap, a 48" Box Blade only works 43" per pull.)
You can tow log sections with a BX and 1/4" Grade 70 chain. Saw trunks into reasonable weight sections. Tractors are designed to PULL.
Cross-drawbar PHOTO.
MORE: https://www.tractorbynet.com/forums/owning-operating/404017-tractor-three-point-hitch-cross-2.html ((Cursor down to Post #14.))
PHOTOS: KUBOTA B3300SU
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is generally greater than depreciation on a tractor.
VIDEOS: Kubota BX Series Genealogy - YouTube
Comparing Finish Mowers (midmount VS 3-point) - Kubota B26�1 - YouTube
/ 2012 Kubota BX2660 #8
I had a BX2660, a 2009 model. It was my first tractor larger than a L&G tractor. I was amazed how much it could lift (FEL) moving tons of gravel, and large stones....around 300-400 pound native limestone rock. It mowed really well with the 60 inch belly deck too. It was trouble free over the three years and around 300 hours of ownership. My 3 acres was not full of wild brush and overgrown trees however.
I did move up to a larger Kubota tractor in 2012 and again in 2017 just because I could and wanted to...am keeping both of them. You may want a larger tractor at some later date, but you can't go wrong with the 50 hour BX2660/price for what you have indicated its usage.:2cents:
I do caution that the attachments that fit BX2660 may not be what you'd want for a larger tractor at a later date. You can sell them if needed but would probably take some loss.
Cheers,
Mike
I
/ 2012 Kubota BX2660 #10
I will give you my input. I had a BX2350, an earlier model of what you are looking at, for 10 years. I mowed with it, moved dirt and gravel, hauled fire wood etc. It did everything I asked. I recently switched to a JD 2025R. It is a size bigger than a BX.
The main difference is bigger tires and a bigger loader bucket. It rides better with larger tires and the bigger loader is nice. I also like JDs auto connect deck.
25 horsepower is a magic number for Diesel engine size not needing emissions equipment.
You can not go wrong with a BX, but I would keep my eyes open for a used B also. BXs are usually a lot more common used.
It's funny that you say that, my other option I was comparing with the Kubota was an older JD 2210. Its a 2007 with 700 hours, but in very good condition. He just lowered the price to $9200 this morning. I'm not sure how the 2210 compares to the 2025R, but I've seen a handful of them for sale. The BX I'm looking at is a 26 horse but it says it doesnt have any emissions equipment. I'm new to the scene so I didnt know that was something I should have been looking for.
Nevermind, the 2025r isnt what I was thinking it was. Definitely a nice machine but I think that's a little out of my price range at the moment.
/ 2012 Kubota BX2660 #13
The JD2210 is a subcompact too - very similar to the BX - maybe a tad heavier and that price seems in line. As others have said for what you want to do and 7 acres you might want to think a B series Kubota, or the L2501 series is another great machine that doesn't break the bank ($17K with Loader) and Kubota has financing too.
/ 2012 Kubota BX2660 #14
My 2025R was about 21k out the door. That is with a loader, auto connect 60” deck, pallet forks and loaded tires. They gave me 7k for my BX with 700 hours for trade in. It had retained over 50% of it original cost. For me a tractor does it all, mow, snow removal, dirt and gravel mover and sometimes just an expensive wheel barrow. I would say with 7 acres it is a must have item.
Well, seller sold the BX2660 out from under me, thought a handshake deal meant more to him. I guess I am back to looking, I think I'm going to hold out for a B series or possibly the deer. Hopefully I can get something before I finally break down and do all the chores I need down now by hand.
Ended up buying a Massey Ferguson GC2300. I believe I got a fair deal on it. So far I'm absolutely loving it.
/ 2012 Kubota BX2660 #19
Pics or it didn't happen!!!
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
