Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,322
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
Bung is better than dung!
And you said it twice. LolYou said 'bunged' three times. :scratchchin:
You must like 'bung'.
I am quite sure he is looking down and approves!Growing up, whenever I couldn't figure something out, Pa was known to say, better take it to town then, pay someone to think for you. Those words play often in my mind when I am trying to figure something out. It has served me well over the years. Wish Pa was still here to see my accomplishments, kids and grandkids..
^^ That one is a new idea. Boiled tractor![]()
Some of this posts do not appear to be sincere......
:confused3:
N-AAAAAA-W...say it ain't true...!!!!!????? I'd be shocked....../s
So many posts now; I have lost track whether this method was ever explored:
1. Grind a flat spot on the face of the bunged up plug.
2. Find short piece of tube that just fits over the bunged up plug.
3. Get a transfer punch, same size as tube interior, and hit with a hammer to have a new center.
4. Drill out a convenient size hole to allow fluid to drain and let drain overnight into a pan.
5. Continue to drill out the bunged up plug till only a shell remains in the threads, caution, do not get into the female threads.
Maybe with lasers and mirrors?This was posted by the OP long ago, not sure which post exactly. It's a large file size, so I won't repost it, just the link. Look at this picture closely, then tell us how you'll get the punch and bit lined up square enough to do what you suggest.
https://www.tractorbynet.com/forums...018-rounded-off-drain-plug-transdrainplug-jpg
I resized the OP's picture from 3492x4656 to 550x733 and posted here as "Large":So many posts now; I have lost track whether this method was ever explored:
6. Using a small cape chisel and hammer and peck out the residual shell.
7. Using proper size tap and clean up the threads.
8. Now using one of the many ideas , in this thread (your choice), on replacement plugs and install it.
8. Fill the reservoir with the proper fluid.
This process has never failed me in 80+ years; on all types of machinery.
Ron
...but why not sidestep the whole problem and suck it out. The plug can stay forever.
Of course this is seems the proper and easiest solution, but the challenge at hand appears not about changing fluids, but rather just removing the drain plug with no regard to the elapse time to the complete job... isn't it? :laughing:Others, (myself included) have suggested the use of a fluid extractor. This is the one I’ve used on the farm.
