3-Point Hitch 3pt supports and their use?
   / 3pt supports and their use? #1
Blunderbore
NC
1993 MF240 w/ 2400QT FEL
I came across these photos of a MF240 with the 3pt lift arms that have additional supports that link to the axle. This is probably a noob question but what would these be used for? Does it prevent the lift arms from going up and down? TIA
   / 3pt supports and their use? #2
Looks to be a stabilizer bar that would prevent the attachment from swaying side to side. Lift arms should still go up and down.
Some tractors did have additional "fixed" stay straps that would connect from lift arms to under top link the don't allow 3 point hitch from raising or lowing. Used for a "fixed" cross drawbar on the 3 point hitch.
Thanks, I thought it may be to limit lateral sway but it also has chains to limit side to side movement.
   / 3pt supports and their use? #4
The chains limit the adjustment, probably so the arms dont' get caught in the tires.
Thanks all!
   / 3pt supports and their use? #6
Bars shown picture are aftermarket (add on's) and more stable than chains as lateral stabilizers... My MF has turnbuckle instead of chains straight from manufacturing for this purpose....
Dale
   / 3pt supports and their use? #8
Going to be really tough to get bars into tires as the add on bars are actually rigid length and pushing inward...
Dale
You missed his point Dale. He meant the chains were there to keep the arms away from the tires. Which is mostly correct.
The add on stabilizers are much better at controlling 3pt sway.
Older tractors used chains and then pin on stabilizers that were usually non adjustable to control sway to a finer point.
   / 3pt supports and their use? #9
Its matter of perspective.... Chains are ineffectual with bars in place, remove bars and chains are again valid....
Dale
   / 3pt supports and their use? #10
Dale
The perspective is his comment. Still missed it.
2017 John Deere 6120E (A53317)
2017 John Deere...
2018 F150 (A56436)
2018 F150 (A56436)
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2018 HINO 268 24FT NON CDL REEFER BOX TRUCK (A59575)
2018 HINO 268 24FT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
