Questions about using my tractor L2501 manual trans
/ Questions about using my tractor L2501 manual trans #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Im gonna have some questions, rather than have 12 different threads Im gonna post them here over time and hope someone will come back and answer them for me.
My dealer was supposed to demo the tractor for me on Fri when I picked up but for whatever reason did not do this ( just left with no notice ) so I was left stuck trying to figure out how to safely operate the tractor on my own.
First questions: There is a high and low range, seems low is much to low for moving the tractor around even on my sandy property, Im not in a rush but putting it in low and then shifting trans to 1st or 2nd gear is stupid slow so would you suggest putting it in H and then is it OK to start out in 2nd gear?
Seems from my experience that 1st gear in either low or high gear was just too slow but I dont want to start out in 2 high if that is gonna wear the clutch faster?
I need to read again my manuals, Ive read them already but need to re read. Im sure I can get alot of my questions answered there.
I didnt get the demo of un attaching the back hoe. A couple of guys at Agricon tried to show me Fri evening but were not successful.
I am real dissapointed in the fact that I didnt get the demo, in my opinion it was a B.S move to have me sign the papers and then not demo the machine as was promised but I cant control that.
/ Questions about using my tractor L2501 manual trans #2
According to the Kubota website, you tractor has 4 gears and 2 ranges. You can use any of the gear/range combinations to obtain the travel speed you wish to use. Clutch wear depends on you, the user. If you ride the clutch or take forever to let out on it, you will wear it out faster. The objective is to engage the clutch fast enough to achieve a smooth transition from a standstill to the desired speed as quickly as possible without popping a wheelie or damaging any equipment.
If you are pulling from your driveway onto the road you would start out in 4 High and take off. If your transmission is fully synchronized, which it appears yours is NOT, then you can shift gears within a range just by clutching as you would in an automobile. With a synchronized tranny you would start out in H1 and proceed through the gears to end up in H4. Typically ranges (H,M,L) are not synchronized, only the gears (1,2,3,4,etc.) are.
The backhoe stuff someone else will have to chime in.
/ Questions about using my tractor L2501 manual trans #3
If it starts nice in 2H it's no more wear on the clutch, do you have experience with manual transmissions?
/ Questions about using my tractor L2501 manual trans #4
The last non-synchro, manual tractor transmission I owned was on a B5100E. You take off in whatever gear you want to end up in - i.e. no shifting while moving.
Watch Youtube for the backhoe removal. My BH70 goes like this:
1) Lower the stabilizers to about 15" off the ground;
2) With the dipper fully retracted and the bucket curled, lower the boom until the bucket touches the ground;
3) Lower the boom a little more to "slightly" lift the rear tractor - tires still touching, just taking some weight off;
4) Remove the upper pins. Tilt the BH forward by using the boom controls;
5) Lower the stabilizers, lifting the BH until the lower pins clear the hooks;
6) Move the tractor forward about 8";
7) Shut down the tractor, move the BH controls around to relieve pressure, disconnect them.
8) **Critical Step*** You will most probably need to allow the hydraulic circuit to complete its path by "patching" one of the tractor's lines back into one of the tractor's couplers. Do not start the tractor without performing this step - lest you cause expensive damage.
I made a stand for mine out of some 2x's and a couple of furniture dollies, so my process is slightly different than what I wrote.
/ Questions about using my tractor L2501 manual trans #5
Firsst off I woud be getting ahold of that dealer and chew some behind. He could be at fault because he did not give you the demo. I would never sign for anything until I was ok with how it works. Now for you question you must shove the clutch all the ay down to change gears with the tractor stopped. When you use the shuttle tractor must be stopped to go from forward to reverse. It will shift at a slow speed but it is better to come to a stop and make sure the clutch is all the way down when doing this. the low or high range lever is just that it slows the ground speed. If I am doing loader work I use low in 3rd or 4 th gear a lot.. If you are unsure how the tractor works just use low gear in maybe second or third gear until you feel more at home with it. If you have a loader ALWAYS move with the loader close to the ground and try to avoid using the loader on a side hill in the high up position as tractor may tip over. Did you get the rear wheel loaded with fluid if do so as it adds weight to help stabilize the tractor. When using the loader it isbest to have something heavy on the 3 pt hitch to help hold the rear down
/ Questions about using my tractor L2501 manual trans #6
Forgot to add it will not star if the shuttle lever in not neutral position and someone sitting in the seat. The seat cane be flipped up and it will start as along as the lever is neutral position. If you ar running it you have to be sitting in the seat at all times or the trator will shut off
Yes with cars plenty, tractors none. I wouldn't start my car or truck out in 3rd gear, to do so means rpm and clutch wear for sure
That's what I had read in manual however the tractor will start wether I am in drivers seat or not and if I want to hop off tractor all I need to do is shift the selector to neutral and get off
Im also wondering if it's possible to not get hydraulic fluid all over my hands when I change front attachments?
/ Questions about using my tractor L2501 manual trans #10
I don’t believe the gears are synchronized on this tractor, so you start out in the gear and range of your choice. Shifting 1-4 can probably done while on the move but I don’t think that is how it’s intended to work.
/ Questions about using my tractor L2501 manual trans #11
Then you have the feeling, just the same with tractors.
/ Questions about using my tractor L2501 manual trans #12
The challenge with tractors and usyncronzed gears are speed, you may stop befor you get the next gear in. And some are more easy to shift quickly without grinding the gears.
/ Questions about using my tractor L2501 manual trans #13
What attachments are you changing to. Usually with quick disconnects you may get a little but not much if any at all. Relieve all pressure from the system before unhooking the lines and it will not reconnect under pressure
Switching between a grapple and the front end loader
/ Questions about using my tractor L2501 manual trans #15
We have a similar tractor L3000DT;you must come to a complete stop to change gears or ranges.You can start in any gear with no problem.Tractors are not like manual shift cars where starting in a higher gear promotes premature clutch wear.
To change hydraulic lines ;drop the FEL and rear third point down,move joy stick around to relieve pressure and the Quick disconnects should be easy to remove with little fluid loss.In summer the lines may be hot and a little difficult to reinstall;loosen a fitting to release pressure.
/ Questions about using my tractor L2501 manual trans #17
The common ag connectors dribble a half teaspoon or so. Usually most of it is in the female half. Sometimes you can keep some of that in when plugging in a new male half. I use a rag to catch the drips.
Plug the grapple's connectors together when you take it off. Keeps the connectors clean and reduces the chances of pressure buildup in the grapple side that would make it difficult to connect later. Use dust caps/plugs on the tractor side connectors. Install some if they were not included.
/ Questions about using my tractor L2501 manual trans #18
No need toloosen the fitting. Shut the tractor off and release pressure on that side with engine off and on the implement side a rag wraped around the fitting just push it down on a hard surface. If it does not release just tap it hard against a hard surface. No toold required and you won't lose any oil to say
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
20 Ton Hydraulic Bottle Jack (A61567)
20 Ton Hydraulic...
2022 Ford F-150 Pickup Truck, VIN # 1FTMF1CB1NKE47600 (A61165)
2022 Ford F-150...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
