Smooth and level gravel driveways...
/ Smooth and level gravel driveways... #11
I use a chain harrow on mine and it looks like new gravel when I get done
/ Smooth and level gravel driveways... #12
The rail weighs 200 lbs added to the 400 lb box scraper. I have since added end plates to the rail to control spillage over the ends of the rail that tends to create brems at the edge of the driveways.
Beautiful dog.
The only problem with perpendicular anything, is that it ejects material out the sides, and off your driveway.
If you weld some oversize end plates onto the rails that should hold the gravel in front and under the rails instead of spilling over the ends ;) I had the same problem until I did that.
/ Smooth and level gravel driveways... #15
Just got a 7000# capacity top dresser at auction. That should spread some nice limestone evenly, rather than dump piles and then try and get the speed bumps out of it. Although, that's not what I got it for. NEW TOYS for spring, if it ever gets here.
Same machine, I just got an older version:
Bannerman Topdresser Demo - YouTube
That AND a flying lawnmower, but that's a different subject!
/ Smooth and level gravel driveways... #16
Since we paved our driveway years ago, this doesn't see much use. Every now and then it does come in handy. The original design used the boom pole for lifting and it was a bit cumbersome. Angling was done by shortening the chain on one side or the other.
A few years ago i discovered an old pipe flange out behind the shop and did some mods so the boom pole wasn't required.
/ Smooth and level gravel driveways... #17
Love the ingenuity with the pipe flange. That great thinking out of the box.
/ Smooth and level gravel driveways... #18
if you can find a land plane/ gravel grader get one - its a must have for gravel driveways. Here is some millings I spread the other day- don't mind the rut - i had a chain dragging and didn't realize it - it was totally smooth when done just didn't get a pic
2006 LIGHTIN 125HP AGITATOR DRIVE GEARBOX (A59823)
2006 LIGHTIN 125HP...
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
DRAGON TRAILER MOUNTED TRANSFER PUMP (A60736)
DRAGON TRAILER...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Iranch IRGC40 High End Mini Golf Cart (A60463)
Iranch IRGC40 High...
