hydraulic manifold ?
/ hydraulic manifold ? #1
wheelbuilder
Upstate, NY
1988 Bolens/Iseki 1502, also Sears GT5000
I'd like to possibly (price dependent) add hydraulics to my 1502 without cutting the lines.
I see some members have had a manifold made. What sort of costs are involved ?
Am I better off trying to source a used manifold ? Is cutting the lines and tying in a better option price wise ?
Sorry for so many questions in one post.
/ hydraulic manifold ? #2
My TX1500F runs the loader from the outlet at the end of the lifting arm ram, then has the return plumbed back via the filling cap under the seat. It isn't ideal as you can't use the loader and rear link at the same time, you have to shut off the loader first - but is is a simple system with no cut lines. I've actually always meant to convert it to a more elegant system but haven't had the time. If I did I would use a control block.
I did find a setup from hoye tractor that would convert the pump hard line to a hose, which I could plumb to a spool and cylinder, then come back to the 3 point inlet. I think I'll investigate this to be sure it would fit, then I'll still have the hard line intact should I need it.
/ hydraulic manifold ? #4
Looks an interesting solution - how do the end fittings connect to the pipe, looks like they need to be swaged on?
It looks like Hoye's setup attaches at the hydraulic pump and provides a fitting to connect to a hose which replaces the pipe. You'd connect this to your spool. The tank port from the spool would then connect to another hose which would attach to a fitting from hoye returning to the point where the old hard line connected to the 3 point input.
I've got to get back to my tractor and check that the fitting would connect correctly.
/ hydraulic manifold ? #6
Here are pictures of the one on my G154/TX1300F
I though I made a sketch of this manifold but I
can't find it. I will take it back off and measure
it and make a new sketch if you are interested.
Thank you, those are a help !
Did you need any special sort of spool ?
/ hydraulic manifold ? #8
The spool valve was already on the tractor when I got it.
I believe the valve and the manifold along with hydraulic
hoses and snow blade were dealer installed. I have
see my setup on other tractors.
/ hydraulic manifold ? #9
It is a little late but I suggest you read the info I provided to another Iseki owner about adding hydraulics.
https://www.tractorbynet.com/forums/iseki/410754-adding-hydraulics-3point-hitch-mounted.html
Your hydraulic system is a "Open Center," one so you cannot just create a manifold to distribute the pressure as, at any control valve, there will be an easier route for the hydraulic fluid to flow than into the circuit where you want pressure. Power Beyond needs to feature in your plans.,
Dave M7040
/ hydraulic manifold ? #10
With only 3GPM and 1850 max PSI...depending on what the op has in mind for utilizing the new hydraulics for...I would consider an independent pump/system...
My hope is to power a pair of cylinders for a snow plow. After reading some more it looks like I could use Hoye's setup to feed a spool with power beyond to run the 3 point. The only thing to figure out past that would be returning the fluid neatly to the tractor, it doesn't seem like it would be neat and clean.
/ hydraulic manifold ? #12
If there is a vent in the tank it could likely be modified to accept a return line...or modifying the tank fill cap...hydraulic returns are low pressure and can be Teed into any existing return to tank line...
I'll look at how I might use the filler cap for a return. I just am trying to think how fxrs55's setup would route the fluid. It seems like it should be simple enough to duplicate.
/ hydraulic manifold ? #14
I think what you will discover is thatfxrs55's arrangement is actually a selector valve like an A or B switch.
Look at this one from prince.
Anytime you have a spool valve, it needs a return to reservoir line. It should also come with a relief valve internally which also uses the return line.
Dave M7040
Prince Manufacturing Corporation > Products > Hydraulic Valves > Selector > Model RD9
That makes sense. I would imagine then that manifold allows the return to be neat and clean while making a passage for high pressure from the selector valve to work the 3 point.
Would that setup retain enough pressure to keep either circuit in position while the other was active ?
/ hydraulic manifold ? #16
The selector valve will lock fluid in the unused circuit. It will send pressure to two different control valves be they one or two spool, but you need two independent control valves. For more cost but less hardware, an electrical two circuit selector will allow you to use one control valve to operate two different circuits. Flip a switch and the circuit receiving power changes.
You find this arrangement on FEL's when the owner wants to add a grapple. The selector valve switches between controlling the bucket to controlling the grapple all by a button on a joystick.
Dave M7040
Thanks Dave, that's a big help !
/ hydraulic manifold ? #18
My manifold is not any type of valve. It is just
high pressure in one side of manifold and out that end to
carry pressure to front blade valve assembly.
high pressure returns from control valves into
the other end of manifold and out the side
via a banjo bolt and the high pressure
then goes into the 3 point control valve.
Its just a pass through. I guess I will
have to take it off so I can get all of the
dimensions to make a drawing for anyone
who wants to have one of these made.
fxrs55 - I'm pretty green with hydraulics but from your pics and drawing that looks like an open spool plumbed neatly in before the 3 point. Pretty much what I was looking at with Hoye's adapters.
Dave - is that how you see it as well ?
If it works, I haven't found any spools that have more than a 500 psi rating on the tank side. I read Ampa's thread and he had issue with a cracked spool housing, I wonder if that's why.
/ hydraulic manifold ? #20
Using the tank port as a supply for another circuit is a common mistake and usually results in the failure you describe of a crack in the valve body. Further, you eliminate a relief valve working properly as it needs a path to the tank to save you from destroying the pump. There is lots of junk hydraulic advice on the web.
This out port pressure restriction is common as you have found.
Years ago companies like Kubota made hydraulic blocks that could be added by their customers in order to acquire more circuits.
The big difference between the 3 pt hitch and the circuits you want to add is the 3 pt uses a single acting hydraulic cylinder, whereas, because you want to control double acting cylinders you need a control valve and not try to use the 3 pt control valve
Dave M7040
2012 Great Dane 53ft. T/A Reefer Trailer (A61568)
2012 Great Dane...
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2015 PETERBILT 579...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
