John deere 2020 hydraulic pump
/ John deere 2020 hydraulic pump #1
westerntruck
2020 john deere
Looking for a good source for parts kit to rebuild my 2020 piston pump. Mainly looking for seals and bearing, the cam and intake and discharge valves look fine. Deere is offering ne an Aand I pump for 1600 .
/ John deere 2020 hydraulic pump #2
Need to know which pump your tractor has(0.69 IN.3,1.38 IN.3) A&I has a new 1.38 IN.3 pump for $796.36 & Abilene Machinery for $585. Did you disassemble pump or pay someone to disassemble pump?
/ John deere 2020 hydraulic pump #3
TxJim, did you ever sell any utility tractors with the optional larger front/main pump? I've never run across any, other than in the parts catalog.
It's an 11 cm3 pump. I'm an independent ag mechanic, Ive rebuilt a ton of 49 and 65cm3 pumps on 40 and 50 series, this ones about the same, just a little smaller. This tractor is actually mine and not a customers. This tractorgot water in the oil and caused the pump to cavitate and shoved the front seal out. I got her all cleaned out, I just want to reseal and put back together.
/ John deere 2020 hydraulic pump #5
Dang I can't remember what I ate yesterday & you expect me to remember something that occurred 50 yrs back!! Seriously I don't remember selling any tractors with larger frt hyd pumps.
/ John deere 2020 hydraulic pump #6
Deere parts shows a seal kit for the 2020.. AR98993
Does it look like the right one?
/ John deere 2020 hydraulic pump #7
westertruck
Parts should be available from your local JD dealer.
/ John deere 2020 hydraulic pump #9
Needle bearing? Parts shows JD9858 for that.. and see that is on your listing too.
Deere changed the parts advisor program, I didn't see that. That's what I need . Thank you
/ John deere 2020 hydraulic pump #11
I hardly remember yesterday also, but remember well 40 years back. 50 years back I was a kid that did nothing memorable
2019 C&M TRAILER 16' COOL DOWN TRAILER (A65643)
2019 C&M TRAILER...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2018 INTERNATIONAL LT625 (A65643)
2018 INTERNATIONAL...
