b3000 cab
/ b3000 cab #1
tony binkowski
green bay packer land
2011 b3000
just installed a product called boom mat inside my cab and WOW! this stuff really works, pulled the seat and did the whole pan, floors, and under the hood! its nice to work with plus has good thermal value! check it out!!!!!!!!!!!!!!!:cool2:
/ b3000 cab #2
Hi Tony.
I also have a B3000HSDCC. Exactly what are you referring to when you say "this stuff really works" ?
Sound insulating abilities that make that cab much more quiet?
Which material did you use? The "Heavy Duty" sound dampening material?
How mush did you have to order/use?
How difficult was the installation? I assume you placed it underneath the oem rubber pad?
Thanks for the info !
/ b3000 cab
I used boom mat XL. yes I did apply it to bare metal on the floor an removed the seat and did the whole pan. I ordered a 10 pack the sheets were 24inch x 12.5 inch an used all but 1 sheet. it really works well! check out boom mat on utube they do a test on a drum snare!!
/ b3000 cab #4
Thank you very much for the info Tony.
In your opinion, did it cut down on the noise & Hydro whine dramatically? 1/2 ?
/ b3000 cab
ya its hard to tell because now all u hear is engine noise, but im half deaf anyway!:laughing:
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2013 CATERPILLAR 416F BACKHOE (A62129)
2013 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
