Another HST Transmission Problem
/ Another HST Transmission Problem #1
Sergei
Gold Member
Vinton, IA
Mahindra 2815 HST
My 2815 hst has 557 hrs on it and now it won't move forward or reverse and I discovered that power steering doesn't work either. Tried Installing both filters and new Chevron hydraulic fluid, but that didn't help at all. Was working fine before putting it always.
Also the FEl , 3 point, PT0 all work
Anyone have any thoughts on this problem? it
/ Another HST Transmission Problem #2
You would have to look in the workshop manual, BUT many tractors use the second section of the main hydraulic pump for power steering operation and also use this fluid flow for the hydrostat charge pump which supplies the "makup oil" that leaks internal to the hydrostat main pump. Some hydrostats have their own built in charge pump, but many of these tractors do not. Without a charge pump flow, your hydro won't go, and without power steering flow from the secondary portion of your main hydraulic pump the steering won't work either. The 3pt and Fel would still work fine as the main pump flow is still working. You need to test the flow from your secondary section of the main hydraulic pump that runs off of your cam.
Looking at the service manual under Hydraulic Pumps I've got a unit located on the engine that has oil pump 1 and also oil pump 2, sounds like what you described. 2 goes to the power steering. And 1 is for Hydraulic Cylinder. Japanese manual are really fun to read and understand.
Thanks for the help
/ Another HST Transmission Problem #4
Thanks for the help
If you have circuit diagrams in the manual, see if you have a circuit from pump 2 section that goes to the charge pump input on the hydrostat. It should be around 200 PSI. maybe a bit more. Possibly no pressure being developed for some reason (internal leak) or no fluid flow coming from the pump. Remember these pumps DO NOT make pressure, they make flow. Pressure develops when the flow meets resistance to that flow.
Final found a diagram on the John Deere forum about a 4200 tractor that identify the components and colored the flows. Makes understanding how it works. The Mahindra manual didn't show anything, just a plain schematic.
This tractor is going to fight me every inch that it can. Trying to check the high pressure before working on the pump just to be sure of the problem and sure enough the plugs are using metric hex, only have standard sizes. Didn't have a 5mm hex socket so off to the farm store to get one, but as usual they didn't have one. Got allen wrench instead and can't break either one loose even after soaking with PB blaster,so most likely rusted. Needless to say not a happy camper today.
Question for anyone with either a 2815 or 3215 series and have you removed the plugs. I'm assuming that they losen counter clockwise,but being Japanese I could be wrong.
Removed pump and the shaft is worn and also the inside gears. I'm guessing the pump frozen, but I'm not sure why there appears to be rust in the inside gear. IMG_20190416_143440.jpeg1555444223795.jpeg
/ Another HST Transmission Problem #8
Water in there somehow? How did that happen?
Looks like rust, it dry inside and powdery where the shaft goes into the housing and I can remove it. The bearing has some bad spots which probably caused the failure. Not sure if it's a dry fit or lubricated. My biggest question yet to be answered is whether the inside grooves are gone. Going to check with local companies for scarp shaft to check.
What I thought was a bearing looks more like oil seal on the shaft. The more I play with it there's has to be wear in the housing for the shaft. When I first tried turning it after removing it I found it was hard to turn.
Just checked the parts list and they show a $3.80 O-Ring should have been between the pump and housing. That's why I had rust and most likely caused the problem. Water probably got in when washing the radiator and lower parts as I've never directly washed the engine.
/ Another HST Transmission Problem #12
Aha... makes sense now.
Since water got in and no telling the damage was done. So to be safe going to start removing case assembly so I can replace the bearing and gear before installing another pump.
Seriously doubt if Mahindra will stand behind their mistake.
Update:
Just talked to them, my fault because the dealer didn't service it and its a 12 year old tractor. They would have seen the problem earlier on. RIGHT !!!!!.
They really have idiots in their customer service.
/ Another HST Transmission Problem #14
Anything to keep from having to pay for a manufacturing defect. That pump wasn't "right" the day it left the factory.
After doing the repairs I'm going to take them to small claims court and try to recover my labor ( $85 dollar per hr) and parts. Being retired I've got nothing better to do, if nothing else maybe they'll have to spend money defending the charge.
/ Another HST Transmission Problem #16
Your labor rate should be same as their posted rate.
Using the rate my local Ford/ Cub Cadet dealer quoted me if they did the work.
/ Another HST Transmission Problem #18
Is your tractor under warranty? If yes, then I have to wonder why you're doing the work yourself, instead of taking it to a dealership for them to properly diagnose and repair.
If it's not under warranty, then oh well. Stuff breaks.
The biggest question I had was whether the grooves had been damaged which would have forced me to replace the gear in the case.
Couldn't really see inside the gear to verify the grooves due to the angle.
Solution I came up with was to cut the spline off the shaft and reversed it to check them. Happy to find that the grooves are not damaged so the gear is a much harder metal than the pump shaft and I doudt
enough moisture got in to cause other issues. Dealer has a used pump that I will get.
Needless to say this has been a learning. experience.IMG_20190419_141202.jpeg
211453 (A62131)
211453 (A62131)
1988 23ft Stealth Craft Boat w 1988 Arrow 22ft Boat Trailer (A61574)
1988 23ft Stealth...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
2025 58in Padfoot...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
