HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #21
First of all, thank you all for an excellent writeup on how to adjust the pressure on the GC 1700 series. I have about a 7 year old GC2610 that I have owned for about 3 years. I have levelled about 1 acre of hilly land, rototilled the same, dug out hundreds of poplar tree stumps, and the machine is great.
Last week, moving about 3 tandem loads of dirt, I noticed the loader was straining to lift a full bucket. I remembered this thread, and went out and bought a 3500 psi pressure guage and tested my loader pressure, as per this thread. I had only about 1300 psi. The adjustment procedure was almost identical, but did not have the same bracket to remove (no 14 mm wrench needed). I was able to adjust the set screw through the opening for the mower deck height adjustment.
I increased the pressure with approximately 1/4 turns on the set screw, each adding about 200 psi, and fine tuned it to 1900, or very nearly the 1920 spec for the GC2610. I have not had a chance to give it a workout, but it surely must be better now, changing from 1300 to 1900 psi.
Thank you once again for an excellent writeup, complete with great pictures.
Jim
Awesome news! I just stumbled across this myself and assumed it would also work on my 6 yr old GC2600. I saw the set screw through the mower height adjustment and knew it would work, but it's good to read someone else actually doing it, and not having a bracket in the way!
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #22
great write up. I did this on mine, pretty simple to do. thanks for posting!
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #23
It's been a long while since I checked the systems pressure on my GC2600. Thanks for the write-up, located the adjustment screw and there were no obstructions, had all tools in hand to tweak and you can imagine my disappointment when it still tested at 2100 psi. Pretty much the same as it did when new in 2009.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #24
I just ordered a gauge I'm curious to see what my pressure is at on my 2010
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #25
Nice write up.
I read only the first page of comments. Be careful on the pressure settings. Blowing a hose is not the end of the world. But going too high and blow a pump is going to be costly. Do not assume you can go higher than recommended on your xy model just because the neighbors yz model runs higher numbers.
Rule of thumb, a hydraulic pump with a aluminum housing can handle around 2000 Psi, a pump with a cast iron housing handles around 3000 Psi.
On most of the compact tractors, the pumps are aluminum, the cast iron pumps you'll find in the bigger farm tractors.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #26
New MF GC1710. Found issue of drift, or bleed down on both FEL and BH. I am installing wire fencing and the drop of the BH is considerable/visible with load. Would the pressure relief valve be the cause of the loss of pressure, resulting in the drop of the implements, weather the machine is running or not? With the BH off the 3pt also bleed down under load. Dealer claims the machine is within specs. I feel this condition (drift/bleed down) could be dangerous.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #27
Nope. Your drop has nothing to do with the pressure relief valve. It sits between pump and the first control valve in the hydraulic circuit to protect the pump. More likely you have internal leaks. It's just surprising that you encounter it on two different items.
Maybe they have the same level of quality that allow this drop. There is nothing to do if it's within the manufacturer's specs.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #28
When off, all of the SCUTs will bleed down and slowly lower their FELs, 3PHs, BH booms and outriggers (if not pinned). While running, every implement, FEL, and BH should hold position regardless of load UNLESS there is a leak or damaged seal.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #29
OK Thank You for that info.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #30
OK Thank You!
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #31
Ordered the gauge so I can routinely check the pressure. Would someone post a pic of where you are connecting the pressure gauge in the FEL system??
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #32
I believe the point where gauge connects to test FEL is mentioned in post #1... For FEL it uses one of the 4 output ports for FEL....
Dale
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #33
Yes but I would still appreciate a photo.....
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #34
Just disconnect a hose leading to the loader, plug in the gauge on the tractor side, rev up the engine, activate the loader function, read gauge.
Easy.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #35
Here is our video showing the procedure on a JD tractor, but it’s the same for all colors.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #36
In the video all the hoses to the loader are disconnected. I was wondering if only a single hose was disconnected if fluid could go through that circuit and spray out the single disconnected hose. Could that happen??
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #37
Most hoses with quick disconnects have a "ball" seal (or some type of seal) so when disconnected there is no "open hose" for oil to leak out of....
Dale
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #38
If that were the case you'd get air in the lines and have to bleed the system every time you took the loader off. The hoses are just like the female quick connects for air compressors and close when disconnected.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #39
On a compressor hose the female coupler seals, but not the male part of the quick disconnect.
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2019 FORD F-150 XL EXT CAB TRUCK (A59823)
2019 FORD F-150 XL...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
KMC 3pt 20' Field Cultivator (A60462)
KMC 3pt 20' Field...
2013 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2013 Peterbilt 567...
