What spreader do I need?
/ What spreader do I need? #1
jmt1271
MO
Kubota L2501
Trying to figure out the proper solution for my needs.
We own 10 acres. 2 acres currently horse pasture with another half acre I'm about to fence in.
5.0 acres on the nose is lawn that I mow.
I mow with a Scag zero turn, and own a Kubota L2501 as well as a Kawasaki Mule Pro.
My needs are as follows.
I need to fertilize all 8 or so acres at various application rates, per my recent soil sample.
But the pasture I need to completely reseed.
I was considering a LP 3 point Spreader, about $850. But that just seems inefficient. Why slowly drive the heavy tractor all over the lawn? Would rather mount a 12v spreader on the Mule or the Scag. Lighter and faster, just more efficient.
That brought me to maybe buying a Herd spreader, 12v, to mount to the Mule.
But I'm still not sure what the right answer is. The Herd, with the ~175# capacity, the model is escaping me, is going to be $800 or so by the time I buy the mount.
I noticed that Fimco offers a utv mounted spreader that can be had for around $350 including a variable speed control.
Sorry, just getting a bit of analysis paralysis. Thoughts or guidance would be appreciated.
/ What spreader do I need? #2
I have an old 3pt spreader that I have refurbished. I fertilize me 3.5 acres I mow in 1 hour going over it twice to ensure even application. I get a 30 ft wide spread with coarse granular fertilizer.
/ What spreader do I need? #3
I use a ATV mounted spreader;rated for 50lbs.Complete control of feed rate with an adjustable gate.I forget what I paid for it but certainly not $350.With a side by side you could just load up the extra in the back and load the spreader as needed.
Check Amazon for ideas and sizes,less than $200 for most.Some fit in the rear hitch;so a simple hook-up.
/ What spreader do I need? #4
If you're not planning on lime a sprayer is the way to go.
I have a nice sprayer, but how to acquire liquid fertilizer? The soil sample recommends 120/70/50 on the yard.
/ What spreader do I need? #6
They make large cone spreaders that have wheels instead of a 3 pt hitch, so you can tow behind an atv or utv.They are around 700 dollars at farm and home stores.
/ What spreader do I need? #7
I know Tractor Supply sells liquid10-10-10 to mix for spraying. Might want to check with the fertilizer dealers in the your area and see if they can get liquid to make a mix.
2018 Bobcat MT55 Ride Behind Track Loader Skid Steer (A66734)
2018 Bobcat MT55...
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
STORGE SPACE WITH MISC ITEMS (A68842)
STORGE SPACE WITH...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
