Anyone have a post driver
/ Anyone have a post driver #1
Barnbuilder
Gold Member
Waxhaw, NC
Bobcat A300, Kubota F3680, JCB 212S sold
Stopped by the Deere dealership to see what they offer. They can get a Danuser with tilt for $8200. I'm tired of boring and packing posts.
/ Anyone have a post driver #2
They dont work here in Colorado. Ground is clay & to hard when dry. 2nd hand info, but was enough for me to understand why they are so scared here. Different story for places with softer ground or more moisture.
/ Anyone have a post driver #3
I have a Shaver HD-8 driver, and love it..!! If you get one, definitely get the hydraulic tilt, you'll thank yourself.
I drove posts by myself back in '12. A lot of trips on & off the tractor, but sure beat tamping in that many posts by hand. I did it through the winter when the ground was damp, it makes a world of difference. I used 5" for line posts,and 6" for corners. 6 incher's went in a little slower, driving them in 4'. But rock solid when you're done.
Don't sharpen posts, because if they hit a rock, and start of sideways, after getting down 2' or so, there is no way you can bring it back to plumb.
It would have gone a lot faster to have a driver, and get lined up to drive,as I'm pretty particular about how straight it is. I carried a small torpedo level in my pocket to keep the posts plumb both ways. With the hydraulic tilt, you can get them back in plumb pretty easy, just check it often, if it looks like it's starting to drive crooked.
My concern is with hard ground. I found a driver I liked with an auger but it was $20k. If I could find a 4" auger I could predrill the hole.
/ Anyone have a post driver #5
Depending on the amount of posts you want to drive it might be cheaper to have someone do it. There is a local guy that charges $5 per post. We are in the process of fencing it 5.5 acres and it was going to cost around $400 to have all of the posts driven. If you are fencing in hundreds of acres then I agree that it would be more economical to buy a driver. I see them come up at auction pretty frequently too.
Well I've been building barns and fencing for 30 years.
/ Anyone have a post driver #7
Depending on the soil there, I've seen 6"x7' posts set 24" down by pre-drilling a 4" auger hole and shoving the sharpened posts into the hole with the FEL of a heavy tractor.
/ Anyone have a post driver #8
Some neighbors of mine have a big post pounder but it is hard to move.
/ Anyone have a post driver #9
We just bought a shaver for our skid steer. Around 2.5k I think. I really like than Danuser vids but no way I could swallow that price tag.
/ Anyone have a post driver #10
The Orchards around me are all switching to using a vibrating attachment on an excavator to put in posts. They say that it breaks less posts and it's easier on the operator then a traditional post pounder.
Aaron Z
I rented a Wheatheart several years ago I got 1 post driven in an hour before it started leaking fluid. Granted it was middle of summer and hard ground.
I like the vibrating type I'm sure it's easier on the posts. Wish I could rent one before I threw down money.
/ Anyone have a post driver #12
Try your Bobcat dealer. A lot of the small orchards around here rent a mini-ex with the attachment to put in posts.
Aaron Z
No one around rents them that I found. The one I rented was from Pasture Management and they're over hour away.
/ Anyone have a post driver #14
Same for us in central WI. We couldn’t find anyone to rent them so we ended up buying.
I looked at the Bradco website and with all the options it was $12k.
/ Anyone have a post driver #16
The neighbor has a old Farmall that has a old post pounder mounted on the front. The tractor has the narrow front end so you can fit it tight areas. It does quite well too.
Kubota dealership didn't offer anything. Bobcat reps Blue Diamond which has a driver and a vibratory driver.
/ Anyone have a post driver #18
I've got an old Shaver HD8 that works pretty well, it would be nice to have some of the more modern safety items and I could see where the hydraulic adjustments would be nice rather than the screw cranks. But the screw crank adjustments aren't horrible to work with either.
Two days ago I put in a few posts for a new pasture I'm fencing off, this is a 9" post at the small end and I put it 3' deep. I did sharpen a point on the end as it is a big post, the ground was plowed about 10" deep a month ago. As always the usual first 12" is easy, I will add the wetter the ground the better and it will still be solid.
/ Anyone have a post driver #19
The local Farm Bureau has a self propelled driver that they rent out for about $100 a day. My cousin just rented it to set quite a few post. He was very impressed with it.
You may want to check around. Hes not a Farm Bureau member so that isnt a requirement.
/ Anyone have a post driver #20
I live in colorado, and I have a post driver, and yes the soil gets dry and the soil gets like a rock,
I prefer putting in posts in the spring when things are wet, they drive very easily, when it is hard, I use a steel pipe that has been pointed and drive it first, (some companies call them rock breakers,) actually I have two of them oen about 3" and one about 6 1/2" I will drive the small one and most of the time I acn then drive the wood post, if it is really hard, I will drive the larger one as well and pull it and then drive the wood post,
I made my post driver, and I think it works well,
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
SDLanch SDLGC80 Electric Golf Cart (A62183)
SDLanch SDLGC80...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
FREE STANDING DELIMBING GATE (A63745)
FREE STANDING...
80003CFL (A61568)
80003CFL (A61568)
2019 KENWORTH T880 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T880...
