MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,980
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
Any idea as to how the bearing came loose? How did you diagnose it prior to removal? Not surprising the parts made it into the filter doing no damage as the cradle is in the case and not in the high pressure loop so the parts would stay in the case if too large or would get flushed out and would need to go through the filter before once again entering the system. Cradle bearings need to be very low friction so the swash plate can pivot easily. All the units I work with have needle bearings but I’ve never been inside a low cost CUT transmission.
