TC-25D Won't Crank - I Need Some Help Please
   / TC-25D Won't Crank - I Need Some Help Please #11
you need to place a DC voltmeter on the positive cable and ground when you try cranking. a battery at 12.1 volts is functionally dead. a properly charged battery should maintain around 12.6 volts during cranking. if that battery shows 10 volts under load, its past dead. just jumping may not help. put a new, known good battery in system.
i also usually ohm out my battery cables between post and bolts to verify there not damaged internally. over the years i have seen these cables damaged internally. they wont allow for the proper amperage during start.
i use a midtronics tester on my problem starters, and i usually see the voltages drop down to the 10v area on dead cell batteries.
Thank you for this solid advice. Consensus seems to agree with your comments - will have to obtain known good battery, and additional pair of eyes and hands and resume testing with battery cables treated as suspect until proven otherwise. You folks are a great help - I'm in awe of the knowledge and expertise being shared. Thanks again!
   / TC-25D Won't Crank - I Need Some Help Please #13
New Holland Yr 2000 Model TC25D with HST. Have had a couple of intermittent failures to crank (before I last replaced battery) which seemingly healed themselves. Solenoid now silent with no start when key fully turned to the right.
  • Slow charged 18 mo. old battery (indicated fully charged)– terminals freshly cleaned and tight – actually load tests at slightly over 10 volts. Removed battery ground wire to frame and sand papered just to ensure solid ground.
  • Headlights and instrument panel lights all operative with ignition switch on.
  • Key turn seems to properly engage glow plug and result in normal pre-heat functionality.
  • Hazard lights work with key removed.
  • Main 30a and all fuses in fuse box visibly good.
  • Test light illuminates/confirms power from battery to single solenoid main lug – all solenoid/starter connections clean and tight.
  • Parking brake light illuminates when brakes set/handle activated.
  • PTO and Mid-PTO levers activate PTO ON Indicator when engaged, turn off warning light when set in “OFF” position. Moved through ranges several times before return to “OFF” positions.
  • HST range lever moved throughout ranges and reset to either (tried both) of the two (2) NEUTRAL positions.
  • No seat safety switch installed on this model.
  • Checked good connection on dual wire push in plug PTO safety switch (PTO ON warning light off if both wires connected or if switch is bypassed with solid copper jumper; warning light on if one or both wires disconnected).
  • Both PTOs, HST range and parking brake safety switches appear visually clean and seem to operate panel indicator lights as operationally expected.
  • HST pedal moved throughout forward and reverse ranges and returned to (Middle) presumed “NEUTRAL” with HST Range lever set to “NEUTRAL” position; All PTO levers in “OFF” position; Parking brake engaged; Clutch pedal fully depressed; ignition key turned fully to right – result is no solenoid noise/no starter turnover.
  • No visible rodent chews or damage on any wiring.
  • Tapped solenoid body with hammer while attempting to crank, silent – no response.
  • Front loader bucket attached with lower blade edge angled down on the ground
Is it likely that these OEM safety switches would operate dash warning lights without adequate current to properly function?
Does anyone know appropriate DMM readings/ranges for each of the safety switches?
Is there a sequential series in which safety switches should be tested using DMM?
If I bypass solenoid and start tractor, will key still shut this diesel engine down?
Is there a testing procedure for this kind of problem in a Shop Repair manual?
Any suggestions on where to get a wiring diagram and/or repair manual for this model? (concerned about downloading some kind of computer virus or getting scammed from websites/sellers I don’t know anything about).
I greatly appreciate any help or advice – I’m obviously not a good mechanic – thanks for your time and expertise.
Very respectfully yours,
TC25Dave - newby
Disclaimer: Make sure tractor is not in gear, loader is hard on the ground, and key is off.
Put power to the key side of the starter solenoid. Starter should spin and bendix engage (even with a weak battery you should at least get a good click out of the solenoid unless the battery is dead). If it spins you have a nanny switch picking on you, if it doesn't and you have 12 volts to the main starter lug, the starter is bad (unlikely).
Best,
ed
Thank you Sir! I will absolutely give this a try. With load tester device attached, current battery will hold at just over 10 amps. Others have pointed out this is probably not enough for proper start function, but your test suggestion will help confirm that the solenoid bendix spins. Perhaps wishful thinking on my part, but I don't think the starter itself is bad. I appreciate your input. I was able to find a wiring diagram, and am trying to go through that to see if I can figure out how to properly test each of the individual safety switch and safety relay functions. As bad a mechanic as I am, I'm finding I'm even worse as an electrical engineer - LOL!
   / TC-25D Won't Crank - I Need Some Help Please #15
I would also suspect a weak battery. If you try to jump your tractor with a good battery and the battery in the tractor is bad, possibly a shorted cell, the bad battery in your tractor can "suck" the energy out of the good battery to the point where the good battery is not effective enough to start your tractor. You could try to eliminate (disconnect) the battery from your tractor and jump from a know good battery.
I've also attached some pages from the shop manual which should help if you need to further troubleshoot.
Let us know what you find.
  • Pages 143-161 Elecrical.pdf
Thanks so very much for all your help. Swapped battery with known good, and nothing. Using details you so kindly shared, pulled the cowlings to get access to the relays. Started DMM testing with ignition switch and confirmed it is bad. Will get replacement switch along with new battery, and remain hopeful that this will solve current starting problem. Could not have done it without you. I'll check back in with everyone as soon as I have more news. Thanks again for your consideration and help!
   / TC-25D Won't Crank - I Need Some Help Please #17
Sounds like you have found your issues.
I had to replace my ignition switch early on with something more robust.
Here is the thread where I documented it:
   / TC-25D Won't Crank - I Need Some Help Please #18
For 20 yrs I've battled similiar issues on my TC35... sometimes I need to take a pipe wrench and rotate the shaft (under the cab) that the PTO lever connects to... their is a safety switch there that does not always close...sometimes just moving and applying pressure on the PTO lever does the trick while cranking with the the key on. Good luck!
   / TC-25D Won't Crank - I Need Some Help Please #19
I'd zero in on the safety switches. Sequentially compress them with a screw driver and try starting with each one over-compressed. When they go bad its not all or none; usually they go bad gradually (accounting for intermittent starts) and when they fail, they will still often work if over-compressed. That helps you identify which one is bad without changing them all out.
   / TC-25D Won't Crank - I Need Some Help Please #20
If you have a 12 volt test light, not a digital meter, hook it to the small actuator terminal on the starter solenoid. When you hit the key/starter, it should illuminate. If it doesn’t, good chance a safety or neutral switch isn’t satisfied.
Then try this. Make SURE you are in neutral, brakes FIRMLY locked.
Apply 12 volts to that small terminal on the starter. Most times, you can source this 12 volt signal from the big battery post right there on the starter. I have used 2 screwdrivers, each to one of these terminals, then cross them to make a connection. A short jumper wire is even more civilized. Don’t be surprised if it cranks! If the key is off, it probably wont start. If the key is on......
Also, you can test the starter motor and cables by jumping the 2 BIG terminals on the solenoid. You’re gonna get some sparks. Use a couple metal bars, 1/2” bolts, something you don’t want ruined, like your favorite screwdrivers.
If all is good, the starter will whirl but not engage. This means the starter motor itself is probably OK, but there is a problem in the solenoid.
I think you said your test light illuminates when hooked to the big battery terminal on the starter solenoid. That’s good, but then hit the starter. If the light goes out, there is not enough amperage (current) being delivered to run the test light and the starter, (for various reason stated in previous posts) and the starter hogs it all. This is exactly what will happen with a battery with one weak cell.
Please make sure the brakes are set and you are in neutral. You wouldnt be the first guy run down when jumping wires at the starter.
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
Kubota L3130 (A53317)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Ladder Rack (A57454)
