Thumb for Subcompact Tractor Backhoe. Need Advice
/ Thumb for Subcompact Tractor Backhoe. Need Advice #1
traderfjp
Hendersonville, NC
LS MT240HE
Hi,
I bought a LS LM125 today with front loader and backhoe. The dealer said he could put on a Titan thumb on my backhoe. He didn't indicate if it was bolt or weld on. I don't care as long as it's done right. I was on the Titan site and there were different sizes. I'm assuming the dealer will go with the cheapest one. Does the Thumb have to fit the backhoe bucket? (newbie here) Am I better off with a different brand.? I can still upgrade, etc. I have to make any changes in the next day or so. I am hoping to use the thumb to pick up rocks in my yard for landscaping. Search results for: 'thumb'
/ Thumb for Subcompact Tractor Backhoe. Need Advice #2
I bought a titan thumb (bolt on) off of flea-bay for $125 about a year ago. I got a slightly larger one and had to add 2 plates to each side of the mount to get it to fit tight on the dipper stick. Wasn't hard to do, but I would suggest that you have the dealer install it. That way, if there are any problems, you can deal with them to fix the problem. Definitely worth the cost!
Looks Nice. Do you think it would help lift rocks?
/ Thumb for Subcompact Tractor Backhoe. Need Advice #4
I'm not sure how the hydraulics are mounted on the LS tractors but on the Kubota BX25 I used to own, the thumb bracket moved and broke off a fitting on the dipperstick hydraulic cylinder. I bought the thumb off of eBay and installed it myself. Fit and function were good, but when I curled the bucket hard against the thumb, the brackets slid up the dipperstick. I didn't notice till I uncurled the bucket and broke off the fitting. After fixing the cylinder I cut and welded two 1/4" steel plates to each side of the dipperstick. You can see them in the attached picture. They prevented the thumb bracket from sliding. Never had a problem after that.
/ Thumb for Subcompact Tractor Backhoe. Need Advice #6
Hi,
I'm very satisfied with my thumb. It was around $350.00 incl. shipping.
/ Thumb for Subcompact Tractor Backhoe. Need Advice #7
Oh it definitely helps. As GRTkub stated, it's easy to apply too much pressure and break things. If you compare pics, I have mine mounted up higher on the dipperstick. This was to allow me to lift a bunch of railroad ties (kinda spaced it to grab them "square"). I also used it that way to grab bunches of brush out of a pile and put onto a trailer.
/ Thumb for Subcompact Tractor Backhoe. Need Advice #8
One more word of caution with the thumb on a small backhoe. It's really easy to twist the dipperstick. I found out the hard way when I picked up a log too far away from the middle. Once in the air, the heavier end twisted it pretty easily. I've graduated to a hydraulic thumb on my B2650 / BH77 but I've learned to be more cautious abut how I lift things.
I'm new to tractors. I think the dipperstick is the part of the backhoe that sticks out just behind the bucket but not sure. Did the metal twist? Was the backhoe toast after that? Thanks
/ Thumb for Subcompact Tractor Backhoe. Need Advice #10
I have the bolt on thumb as well, with some shim plates welded to the dipperstick to make it fit and they have "ears" with holes for the thumb bolts so it can't slide. Very useful!
The dipperstick is the second part of the backhoe "arm", between the "elbow" and bucket.
/ Thumb for Subcompact Tractor Backhoe. Need Advice #11
I managed to twist it back into shape. The new owner is still enjoying it.
Should I go with Titan or are their better designed Thumbs for the LM 125?
/ Thumb for Subcompact Tractor Backhoe. Need Advice #13
For a 24.7HP machine like the LM 125, I think the Titan thumb should be fine.
The hoe bucket force is only 2097 lbs.
I was worried about fitment. It looks like Titan makes a bolt on. Not sure I trust the dealer to weld it on.
Does anyone know the right size for the MT125 backhoe bucket??
Found this:
Features:
- Bolt-on design
- Folds out of the way when not in use.
- Please measure your bucket before ordering
- 5 possible positions
- Fits backhoes with up to 3 3/16" boom width
- Kubota BX25, BX24, BX23, BX22, BT601, BT751, Woods BH6000 Groundbreaker Backhoe, Titan Fronthoe, Mahindra 1710 Backhoe
Specifications
- Material: .4" steel body, and 1" steel support
- Jaw length: 16.5"
- Opening width: 3 3/16"
- Finish: Powder Coated
- Weight: 42 lbs
Backhoe Thumb Excavator Bolt On Universal Claw Tractor Attachment Kubota Deere
2011 Ford F-250 Pickup Truck (A61573)
2011 Ford F-250...
3142 (A63117)
3142 (A63117)
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
New Holland 216 Rake (A63688)
New Holland 216...
