Bolt on hooks
/ Bolt on hooks #61
So it was a little scary drilling holes in a brand new tractor, but I got my hooks from Ken installed today. Easy 15 minute job.
Ahh - I remember that feeling. But in 20 years it will be covered with dodaads you added and it will feel like it is really your tractor. You will like those hooks !
gg
/ Bolt on hooks #62
I have a question for you engineer types and those that have abused bucket add ons. To spread stress, prevent distortion and cracking,shouldn't the hooks be mounted on plates with bucket sandwiched between? Yea,I know that mean's drilling more holes. If one chose's to weld,it would seem especially advisable to weld hook to a plate then weld plate to bucket rather than welding hook to bucket.
/ Bolt on hooks #63
I wanted hooks for my FEL and could not locate those 'weldable' versions.
I took regular 5/16 th and cut/ground to a suitable shape.
Besides the regular hooks were about 75% less than the 'weldable' versions.
Then welded them to a 3 X 4 HD flat stock and then welded that 3 x 4 plate to the top of my bucket.
That's like 12 years ago and gotta tell you they have done HD duty and never complained.
Bucket is still nice and straight.
OK, I needed to touch up the bucket paint but some black Tremclad took care of that.
/ Bolt on hooks #64
Ken actually sells some pre-made, pre-drilled backing plates that you can buy to use in case you want to mount the just the clevis without the hooks. The price was reasonable. Check out his site. You may need slightly longer bolts depending on what you do.
/ Bolt on hooks #65
Yup. I did exactly what your thinking with the weld ons. Welded them to a 3"×3" chunk of plate and then stitch welded the plates to the bucket. I figured it would be easier to fix if one broke but I have yet to break one and I've been rough on em..
207271 (A52708)
207271 (A52708)
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2016 POLARIS RANGER 900 UTV (A64047)
2016 POLARIS...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
Butler MFG Water Tanker (A63118)
Butler MFG Water...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
