Starter for y380t.
/ Starter for y380t. #1
skippy969
2004 Nortrac 204C
What starter fits the y380t 3 cylinder engine?
/ Starter for y380t. #2
/ Starter for y380t. #3
Thanks for the Referral, yes the QDJ1332A is a reduction type and works a lot better and is sealed a lot better so it will last longer. Either way we have both ,the standard starter is a QD100C3
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
979-865-4002
I don't know if the starter is bad. I'm pretty sure the solenoid is bad though. If I bypass the solenoid the starter spins. If I touch the battery post to the small post on the solenoid it clicks, but does not turn the starter. If I hold a screwdriver to the battery post and the little post, and another screwdriver to the battery post and the other big post, the engine turns over. It also heats up the clamp on my jump starter and turns the spring red hot and bends it. My question is why to all of this. Even why it turned my clamp spring red hot. I only held it for 5 seconds or so. Also, how fast can I get a solenoid?
/ Starter for y380t. #5
I ordered a new starter, put fuel in and the bowl was cracked. Ordered a new bowl, put fuel in and the engine started right up. After sitting for 10 years the engine started right up. Now I need a thermostat and some antifreeze to see how long it will run.
/ Starter for y380t. #7
Your jumper cable clamp heated up because you were pulling a butload of current thru a thin piece of metal with a small contact area. Thats how heating elements work:)
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
x (A68191)
x (A68191)
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
DYNAPAC  CP271 PNUEMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP271...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2022 Sany SY35U Mini Excavator (A66734)
2022 Sany SY35U...
