Kubota Zero Turn Starting Issue Z125S
   / Kubota Zero Turn Starting Issue Z125S #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
When I go to start this machine I have the battery fully charged and all it does is groan. I thought it was the battery so I put in a new one this morning and have the same issue.
I have proven all safety interlocks work to include control handles, parking brake, electric mower clutch, seat switch. The lights work too. I have isolated it to the click at the starter, and checked all fuses. Power goes to the starter but it won’t turn over. Any ideas please?
   / Kubota Zero Turn Starting Issue Z125S #2
clean both battery cable connections maybe w/baking soda? or proper cleaner. sandpaper also works well. disconnect the starter positive connection & do same. then look for all ground connections, remove & clean. std procedure as with any battery issues. best regards
good idea. OP: how many hrs?
Only 82. Had belt issues first two years it was at dealer more than here. Kubota stepped up and did the fix.
   / Kubota Zero Turn Starting Issue Z125S #6
then start off by cleaning battery/starter/ground connections. let us know, mowing season will be on us, but a while up in your area
just finished going through my own
as far as belts, if premature failure i recommend kevlar reinforced, big difference over stock replacement imho
Vbelts4less - Mower V Belts - V-Belts - Banded V Belts - Kevlar V Belts - Cogged V Belts - Industrial V Belts
Hey Bubba, thanks for the advice. I swear I will toss and turn all night thinking about this stupid thing. I know it will be a simple fix but still bugging me. Thanks to all on the site for your help, I will work on it tomorrow all according the weather.
   / Kubota Zero Turn Starting Issue Z125S #8
rest easy....while the grass grows :)
   / Kubota Zero Turn Starting Issue Z125S #10
Replace the starter solenoid. Had the same issue with my Z122R.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
John Deere 455G Loader (A48837)
John Deere 455G...
6 Yard Commercial Dumpster (A49346)
6 Yard Commercial...
Set of Ag R4 Wheels and Tires (A50397)
Set of Ag R4...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
