Kubota Zero Turn Starting Issue Z125S
   / Kubota Zero Turn Starting Issue Z125S #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
When I go to start this machine I have the battery fully charged and all it does is groan. I thought it was the battery so I put in a new one this morning and have the same issue.
I have proven all safety interlocks work to include control handles, parking brake, electric mower clutch, seat switch. The lights work too. I have isolated it to the click at the starter, and checked all fuses. Power goes to the starter but it won’t turn over. Any ideas please?
   / Kubota Zero Turn Starting Issue Z125S #2
clean both battery cable connections maybe w/baking soda? or proper cleaner. sandpaper also works well. disconnect the starter positive connection & do same. then look for all ground connections, remove & clean. std procedure as with any battery issues. best regards
good idea. OP: how many hrs?
Only 82. Had belt issues first two years it was at dealer more than here. Kubota stepped up and did the fix.
   / Kubota Zero Turn Starting Issue Z125S #6
then start off by cleaning battery/starter/ground connections. let us know, mowing season will be on us, but a while up in your area
just finished going through my own
as far as belts, if premature failure i recommend kevlar reinforced, big difference over stock replacement imho
Vbelts4less - Mower V Belts - V-Belts - Banded V Belts - Kevlar V Belts - Cogged V Belts - Industrial V Belts
Hey Bubba, thanks for the advice. I swear I will toss and turn all night thinking about this stupid thing. I know it will be a simple fix but still bugging me. Thanks to all on the site for your help, I will work on it tomorrow all according the weather.
   / Kubota Zero Turn Starting Issue Z125S #8
rest easy....while the grass grows :)
   / Kubota Zero Turn Starting Issue Z125S #10
Replace the starter solenoid. Had the same issue with my Z122R.
2009 IC Corporation PB105 Passenger Bus (A48081)
2009 IC...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
Desk (A50860)
Desk (A50860)
2015 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A49346)
2015 Caterpillar...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
GM Coach Bus (A50860)
