New Member. Seeking Advice
/ New Member. Seeking Advice #1
Yuhong
Kubota L3301
Hi,
I am in in a small town Prunedale (next to Salinas) in Central Coast CA. My farming experience is limited to watching other people working in the field. We purchased a 15 acre residential lot with about 6 acres of useable land for planting.
I bought a KUBOTA L3301TLB almost brand new (20 hours). I am in the process of getting a disc harrow and box scraper. I will need a bottom plow to complete my list for spring field preparation.
I will ask quite a bit questions.
Thank you all.
Digou
Thank you, Sir. I am a weekend farmer and new in that area. Have not had a chance to even meet my neighbors yet. We had some decent rain and I will have to hurry to prepare the field. I was thinking of none chemical fertilizer farming (for sure no synthetic pesticides), so I will need a plow to turn the compost into the soil. I read quite a bit on the plows and still not clear on what would be a good fit for my tractor.
I am still figuring on how to work with this site to get the most of it, and hopefully contribute to the community someday.
Thank you.
Digou (This is my nickname)
/ New Member. Seeking Advice #4
A Kubota L3301 is marginal at 2,700 pounds bare tractor weight for pulling a useful weight Disc Harrow. L3301 will pull a two-bottom, 12" moldboard plow fine. Horsepower is adequate for both Disc Harrow and plow. But without more tractor weight you are marginal for ground contact applications, particularly a Disc Harrow. Few would use a plow/disc succession for six (6) acres.
I recommend a forward rotation PTO-powered roto-tiller rather than the plow/disc succession. One piece of easily learned, effective equipment rather than two, with the Disc Harrow with 18" diameter pans, all the Disc Harrow a light tractor can pull, marginal. A plow takes most small field users several seasons experience to invert soil evenly. A Roto-tiller will mix compost into soil easily.
VIDEO: tractor rototiller - YouTube
I have such fond memories of Salinas in 1966. I was in Navy electronics school on Treasure Island. Would occasionally visit Salinas for fried baby Artichokes, which I clearly remember were 35 cents for a generous portion on waxed paper in a white cardboard carton. Navy Payday was twice monthly. $34.00 per check, twice per month.
/ New Member. Seeking Advice #5
Good advice on the roto-tiller;much better use/fit for small tractors.I would suggest breaking the sod with a "potato plow/middle buster($150 or so) and then the tiller.First year will be the most difficult,after that pretty easy.
/ New Member. Seeking Advice #6
VIDEO: tractor middle buster - YouTube
PLEASE ENTER YOUR PRUNEDALE, CALIFORNIA LOCATION INTO YOUR T-B-N PROFILE.
/ New Member. Seeking Advice #7
:welcome:
Welcome to the forum!
Congrats on your new land and Kubota :)
/ New Member. Seeking Advice #8
:welcome: to TBN...enjoy.
Thank you, Sir. The soil has a heaver layer underneath. That is the reason I did not pick a rototiller at the first place. Once I get enough organic matter in the soil in a little deeper, I will switch to a rototiller and then add some compost every year.
I used to take some sample from artichoke field, then we ate them. But never tried to fry them. I will try that next time.
Thank you.
Yuhong
/ New Member. Seeking Advice #11
Tractor's Three Point Hitch hydraulic control allows you to control Roto-tiller depth in 1/4" increments if desired, although most moderate price Roto-tillers should mix heavy soil in 2" increments at least.
A Commercial Grade Roto-tiller should allow your L3301 to mix heavy soil in 4" increments at the minimum.
Do not mix infertile Subsoil and fertile Top Soil.
Jeff and all,
I made a stupid mistake and am seeking advice.
I disconnected the backhoe to hook up the disc. While disconnecting the backhoe, I DID NOT RELEASE the pressure in the Hydraulic Line in backhoe. After using the disc, I tried to hook up the backhoe and the hydraulic line would not be able to be connected. After some discussion, we realized that there was some pressure trapped in the hydraulic line preventing the line to be connected.
Right now the backhoe is still sitting on the ground. What would be the best and easiest method to release the pressure in the backhoe's hydraulic line? Then I can reconnect the backhoe to the tractor.
Thank you all very much.
Digou (408-688-4299 - cell)
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A60736)
2012 VANTAGE...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
17601CFL (A59228)
17601CFL (A59228)
iDrive TDS-2010H...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
