New Member. Seeking Advice
   / New Member. Seeking Advice #11
The soil has a heaver layer underneath.
Tractor's Three Point Hitch hydraulic control allows you to control Roto-tiller depth in 1/4" increments if desired, although most moderate price Roto-tillers should mix heavy soil in 2" increments at least.
A Commercial Grade Roto-tiller should allow your L3301 to mix heavy soil in 4" increments at the minimum.
Do not mix infertile Subsoil and fertile Top Soil.
Jeff and all,
I made a stupid mistake and am seeking advice.
I disconnected the backhoe to hook up the disc. While disconnecting the backhoe, I DID NOT RELEASE the pressure in the Hydraulic Line in backhoe. After using the disc, I tried to hook up the backhoe and the hydraulic line would not be able to be connected. After some discussion, we realized that there was some pressure trapped in the hydraulic line preventing the line to be connected.
Right now the backhoe is still sitting on the ground. What would be the best and easiest method to release the pressure in the backhoe's hydraulic line? Then I can reconnect the backhoe to the tractor.
Thank you all very much.
Digou (408-688-4299 - cell)
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A56435)
2003 International...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
2020 DRAGON ESP...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
