Tractor Problem: no Forward Movement
   / Tractor Problem: no Forward Movement
Hi nybirdman, Ray here. I don't know much about tractors, so please excuse me. What cable and where is it located. Thanks I 'll look into that tomorrow. Thanks much.
   / Tractor Problem: no Forward Movement #14
I was just thinking if reverse also gets worse in higher gears it might be clutch related.
   / Tractor Problem: no Forward Movement #15
in most vehicles i have reverse is a lower gear than forward gears. if that is the case with this tractor that would mean that reverse works better because it is lower which sounds consistent with the lower forward gears working better.
cold clutch fork be compromised or bent/cracked? otherwise clutch sounds like potential culprit. Throwout bearing failure?
   / Tractor Problem: no Forward Movement #16
He has 4 reverse gears, and it seems each is a little faster than the same gear in forward.
   / Tractor Problem: no Forward Movement #18
Hi DL, Ray here. Thanks for the site address which you texted me, I found it to be interesting and informative. I appreciate it since I don't know anything about tractors. The information, 4WD, on the fender and what it stands for blew me away. I thought it was only to identify the tractor to be a 4 wheel drive. Thanks and may GOD be with you and yours.
   / Tractor Problem: no Forward Movement #20
After some thought, and digesting other peoples input, I really think you have a clutch issue... Either badly worn (slipping) or improperly adjusted....
Dale
15ft Batwing Rotary Brush Cutter Tractor Attachment (A55851)
15ft Batwing...
40' CONTAINER (A57192)
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 John Deere CX15 (A53317)
2015 John Deere...
AGRI-X 5' ROTARY MOWER (A57192)
AGRI-X 5' ROTARY...
