RK Block Heater
/ RK Block Heater #1
snymat68
Monroeville, PA
RK24H, Gravely 8123
Has anyone purchased the block heater for the RK24, or for any of the RK tractors for that matter?
Is it difficult on install? Wondering if oil needs drained to install it or if it fits into a separate cavity that doesn't open into block?
/ RK Block Heater #2
Matt, I live up in Cleveland, and I have an R24, that I keep in garage. I have not had to use block heater. Just the glow plugs to warm up and I have not had any problems starting. I did add fuel additive over winter to keep from gelling up.
mike
/ RK Block Heater
mike
Right now it's in my garage, which never gets below 50°F. But it takes up too much space in the garage, and I'm going to be building an unheated shed out back for the attachments. So I'm thinking about making the shed big enough to store the tractor too. We sometimes get in the negatives here in the winters, which is why I'm thinking about the block heater (as well as possible oil pan, trans, and battery heaters too. The shed will have power, so that won't be an issue. And yeah, the fuel additive is a given. Just thinking of things that might make my life easier should I decide to use the RK for snow removal or anything in the winter.
/ RK Block Heater #4
Matt,
That sounds like a plan. When I first got my Rk24, I looked into block heaters, "magnetic type" however, for some reason, I opted not to get it. If I had an out building, I think I would put a torpedo heater in there and have a cup of coffee while it thru some heat. As well, for the battery, you can get a battery maintainer. I had one on my ATV, that I kept on all winter long. The guy that can tell you for sure is RK Tractor Guy. I figure this way, If RK didn't sell the block heater, etc, you probably would not need it?....
Hope all is well back home
/ RK Block Heater #5
are you sure it does not install in the water jacket part of the block? That would be in your antifreeze and not your oil?
/ RK Block Heater
I have no idea. That's why I posted the question. There's no documentation or mention of it anywhere on the website. I didn't even know it was an option until they updated the site and I saw it in the price list.
/ RK Block Heater #7
on my NH the block heater is in a freeze plug looking hole in the side of my block.
a magnetic heater that attaches to the oil pan also works well without installation requirement. i used magnetic before i installed the factory one in block. a little easier to use the block type once it is installed but you have to install it. either will work fine and neither is very expensive. my magnetic one has a cord that unplugs at the heater so sometimes i left it on while i plowed snow with the cord removed. this leaves you with the possibility of knocking it off though so i suggest you remove it once you start the tractor. SEE .. do as i say say not as i do :)
/ RK Block Heater #8
as far as I know neither has a thermostat so i bought a plug adapter that has a thermostat in it that i plug the extension cord into that comes on around 40 deg. think it was about 25 bucks. I just didn't want the heater running all the time even if it was above that setpoint.
/ RK Block Heater #9
I have never even heard of any heater that installs in the oil system.
Block, or hose heaters, install in the coolant system.
/ RK Block Heater #10
No Offense meant, but if you don't know that it doesn't have anything to do with motor oil, but with antifreeze in the water-jacket I'd let a professional do the work
/ RK Block Heater #11
You might try RK to see which heater they recommend for the RK24. They might have one on the shelf and they should be able to steer you correctly on the install.
Ask The RK Tractor Guy
/ RK Block Heater #12
except when it is really cold you likely do not need a heater. if you are at all unsure about installation just get a magnetic one and note my previous comments about them. Very simple.
i got this a couple years ago for $44. I see it is more from this particular vendor so don't jump on any that are too high. Almost end of March so you should not have to decide till next fall
good luck
/ RK Block Heater #13
good luck
Yup ....... magnetic is "Very simple".....and also.....Very poor at heating the oil pan.
/ RK Block Heater #14
kept my tractor starting in sub freezing temps
/ RK Block Heater #15
As others have said, block heater heats the antifreeze and yes you want to drain first.
Magnet heaters, I have 2 and was told they are not very effective by multiple people. (You can get these off the shelf at Oreilly's and it's the one with the best reviews on Amazon.
I have rk37 and installed the block heater. I bought a low profile socket but still ended up loosening the alternator in order to feed the socket in from the front. Its tight in there. I imagine the components on the rk24 are pretty different around the engine.
Pro tip: Route your power cable in a way that you cant miss/forget it and try to drive away with it attached. I have a cab and I think I will put it through the door handle. Without a cab I would probably lay it across the seat. In the least leave some slack so that if by chance you forget it, it gives you time to catch it as you realize the cable starts moving with the tractor.
/ RK Block Heater #16
There is a post where a dealer installed a heater in the freeze plug, ie expansion plug on a new tractor. The owner was using it and it popped out, leaking coolant with less than 8 hours. Didnt register on the coolant gauge because it requires coolant to read properly. Did some damage. Dont know if its resolved.
Get a Kats peel and stick to your new clean oil pan.
https://www.amazon.com/kats-oil-pan-heater/s?k=kats+oil+pan+heater
IMHO coolant heaters cause oil to run off internal surfaces causing a dry start.
Warm the oil in the pan, starts easier and you arent causing any premature wear.
/ RK Block Heater #17
I have a 200W Kats magnetic oil pan heater.
It simply cannot provide enough heat, in below 10F weather (on CUT oil pan), to provide any meaningful temperature increase to the oil.
It sits on the shelf in my barn.
There is apparently a 300W version available, but it is likely not adequate either.
/ RK Block Heater #18
Magnetic looks like it could be iffy with surface contact especially if it’s dusty, muddy etc.
There is a 500w version in the link I posted, maybe you could use two, one on each half of the pan?
Some blogs say this works great, peel and stick.
https://www.amazon.com/Zerostart-3400064-Wolverine-Reservoir-Hydraulic/dp/B00PM669MU
Here is the Kats 500w part #24500 $25 ebay
Kat's 245 5 Watt 5.5" x 8.5" Universal Hot Pad Heater 68999822467 | eBay
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
2017 Mercedes Benz GLS450 AWD SUV (A61569)
2017 Mercedes Benz...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2014 Ford Focus Passenger Car, VIN # 1FADP3F21EL104239 (A61165)
2014 Ford Focus...
(2) UNUSED 18.4-30 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED 18.4-30...
