Land Scape Rake?
/ Land Scape Rake? #1
hks003
Monticello, AR
2014 LS G3038
I recently purchased a 2014 LS G3038 with FEL. I bought it to maintain my 4 acres, 2/3 of which is open grass, but on a hill and pretty bumpy, and the rest is a combination of pine trees and a few hardwoods. The biggest battle I fight is keeping the leaves and limbs picked up to an extent where I can mow with my zero turn (I plan to bush hog the areas that are farther from the house now though). I was hoping the FEL would suffice, but I find myself using it to drag everything in a pile and then still having to pick them up by hand/shovel/rake into the bucket to haul it off. Would a landscape rake benefit me here? I'm tearing my yard up with the bucket (it doesn't help we've not had more that 3-4 days in a row with no rain since November), but I have to get limbs picked up before I can start mowing in the next month or two. I've looked at grapples as well, but that's an expensive endeavor since I'd need a 3rd function as well. Anyone have experience moving small debris with a landscape rake? It's about an acre and a half on a gentle hill that I'd be using it for. Any other attachments that I'm missing that would benefit me more?
Thanks!
/ Land Scape Rake? #2
I've collect branch/limbs before w/my rake,just go slow and be ready to left rake contact w/root...do you have wheels on the rake?
/ Land Scape Rake?
I don't have a rake yet, I'm still trying to find exactly what I need.
/ Land Scape Rake? #4
The rake is a pain and you still have to pick branches up at some point. Small branches get wedged between the tines...sometimes get stuck in there tightly. If there is a large area with a lot of smaller branches down, brush hogging is one way to grind them up. If there are not a lot, I wind up picking them up by hand.
I am getting a bolt on grapple this year for my FEL. Ordered the diverter valve last night (<$190) and will order The Thumb The Thumb - Add-on Grapple Attachments
It seems like a cost effective way to handle the larger stuff.
BTW, welcome to TBN!
/ Land Scape Rake? #5
A rake works ok , for stuff larger than 1-1/2” diameter, you can remove every other tine which helps a bit and go slow. You will disturb the ground and pull out grass so if that’s a issue then I’d stay away from a rake. It’s not going to get the small stuff you’ll still be faster just picking them up by hand.
/ Land Scape Rake? #6
Anyone have experience moving small debris with a landscape rake? It's about an acre and a half on a gentle hill where I will use it.
I have an ETA Landscape Rake and a Ratchet Rake bucket attachment. The Ratchet Rake is so much more versatile, the Landscape Rake mostly sits. The Ratchet Rake is far better at corralling leaves and yard debris and moving piled debris short distances. The Ratchet Rake also grades pretty well, if you are not in a hurry,
I use the Landscape Rake on a 45 degree angle grading rutted dirt roads at a faster clip.
LINK: Ratchet Rake, LLC - All Terrain Rake, Tractor attachment, Bucket attachment, Loader, Skid loader, Kubota, Skid steer, Landscape rake, Brush remover. Tractor rake attachment, Construction attachment, Fire safety, Home fire safety, Fire prevention.
/ Land Scape Rake?
I like that look of that Ratchet Rake! The straps don't get in the way?
/ Land Scape Rake? #8
/ Land Scape Rake? #10
I thought this was a lawn and garden tractor sub forum? Seems like you are discussing 3-point attachments for a sub compact?
/ Land Scape Rake? #12
I have the same issue and bought a big landscape rake. It succeeded in tearing up the lawn, and not moving a single branch or stick.
Bought a pine needle rake and it works much better. Not great, but better. It will work good in the spring, in a dry spell and will also do a fair amount of thatching as well.
/ Land Scape Rake? #13
Yard Tuff is the one I've been eyeing. Just don't know how sturdily they're built.
/ Land Scape Rake? #14
The old dump hay rake would work really well for small limbs.
They do not tear up the ground like the landscape rake.
As a kid back in the 60's (about 10-12 years old) I use to ride on the seat of a dump rake in hay fields and would operate the dump feature
with a foot pedal mechanism while my dad drove the tractor.
I used one a few years ago and operated the dump mechanism with a length of rope, as I drove the tractor.
They do amazingly well raking up lengths of hay, straw, limbs and even leaves to some degree.
Around here you can still find them for $100-$200, if they haven't been painted up fancy for lawn ornamates.
/ Land Scape Rake? #15
A combination of a tine bucket and the landscape rake might be your best bet. I got a landscape rake and a tine bucket from Titan Attachments
Titan 72" Tine Bucket Silage Rake Manure 27" Hay Bale Spears Skid steer loader
This early winter, we logged my property. I am looking at several acres of limbs, stumps, rocks, and other debris to clean up this spring. I got the landscape rake, but decided that I would probably use the tine bucket more. I put the rake on and cleaned up my front yard, it works... ok. Only when pulling it. Pushing it? no. Which means that I have to drive over top the pile to drag the rake over it. This is why I sprung for the tine bucket. I havent used it yet, as winter finally came and everything is under about 2ft of snow. But it should work just fine.
I am impressed at how well built it is. I got the 39in tines on a 72in frame. Those tines are stout! I'll probably still bend them, but I am hard on equipment. :D
/ Land Scape Rake?
Thanks! I'm liking the ratchet rake at this point. If nothing else, I can pile everything up at the base of the trees to allow me to mow. The main objective is not to have to change my blades every 3rd mow because I hit a 2" limb under a pile of leaves...
/ Land Scape Rake? #18
Enter your tractor brand and model in your T-B-N PROFILE, replacing "none".
It would be helpful to have an approximate location as well.
/ Land Scape Rake? #19
Thanks!
I think it would. I recently bought a Land Shark LS-CMP-LR-72 Landscape Rake, which is 6' long. It's actually made by Everything Attachments, but comes in Orange. It's not cheap but it's built like a tank and well worth it. The most important feature I was looking for was an offest option where the support arm pivots at the 3 point so that the rake can be swung out to the side past the tires. I've attached a few pics. I believe you'd find many other uses for it as well. If you want to avoid tearing up the grass, then consider getting gauge wheels for it.
500 Gallon Pull Behind Sprayer (A61166)
500 Gallon Pull...
John Deere 6400 Tractor w/ Bush Hog M446 Loader (A64047)
John Deere 6400...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
John Deere 4044M (A60462)
John Deere 4044M...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
