Need help with loader model
/ Need help with loader model #1
bazman82
Gold Member
Lockport, NY
Same Mercury 75 Farmtrac 795DTC
I am trying to figure out which model my loader is and was wonder if there was any help out there. I have pictures attached (not the best) and the tags in the 1 photo are just warning labels. I haven't found any other markers on it. From just a quick search I believe it to be a Deutz-Allis brand loader but not sure the model. All the pictures I have seen have one stand leg (not sure correct term) centered on the cross bar just behind the bucket whereas I have 2 stand legs just below the cylinders that raise and lower the loader.
Yeah. It's a KMW K600. I found the tag. I shouldve looked better before posting...now I just need to find a quick attach for it.
/ Need help with loader model #5
Awesome!
HLA likely can build one, they've probably built one for KMW loaders before. I'd go with Euro.
Awesome!
Why Euro? Most attachments I see are the skidsteer type.
So an HLA quick attach adapter (skidsteer type) would cost just a bit over 1,400....That's the price I got from 1 of the dealers around me.
/ Need help with loader model #8
How much was the Euro one? Wow. HLA builds really good stuff, I don't have an HLA adaptor, but several attachments etc.
Euro is strong than skidsteer mount (better hooks and positive cross pin latch) and is the standard for farm tractors now. Also latches from the seat on rollback (normally) so you don't have to get off the tractor once you pick up the attachment.
If you have access to a lot of skidsteer mount attachments, than that might make better sense.
I never got a price on a Euro one. The salesman at the dealer was more for the skidsteer mount. He questioned about Euro being standard. Maybe it is becoming standard everywhere but usa? He did assure me it would be heavy duty and I would agree HLA looks like they make some beefy attachments. I assume that is why they are expensive (the manure/debris grapple I want from them is 4400). Also, I have never seen Euro style attachments at any of the auctions I have been too. If I have, it is very rare, which is why I will most likely stick with the skidsteer style.
/ Need help with loader model #12
Skidsteer is the standard for Compact Tractors, with Utility 50-80 PTO HP likely being split Euro/Skidsteer. Anything 80 PTO HP and up is going to have Euro or "global" coupler now. My Kubota loader was available with Euro or Skidsteer new, I got Euro, very easy to get attachments here, in stock on the lot.
I do bet it's regional preference too. If your local dealer sells all skidsteer and you have lots of options for used, than Skidsteer might be the better choice.
/ Need help with loader model #13
2015 John Deere 1775NT Planter (A63109)
2015 John Deere...
New 2025 NextGen 7x12 Utility Trailer (A61166)
New 2025 NextGen...
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
FEEDER (A62131)
FEEDER (A62131)
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
