pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,438
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
I'd like to see how this story ends.
Even the "window" framing is all wrong. There should be king and jack studs and headers. I see none, at least not in a proper way. This honestly looks like somebody used up scrap lumber in a haphazard attempt to frame a wall, and ignored all standards and codes.
But how many vertical members are there that go all the way from top to bottom? Or that go from the bottom section past the second or third window on the end wall?
I'd have liked to seen solid studs in the places I've indicated with blue, with trimmer studs supporting the window framing and headers. .
The vertical walls were built with a hinge in the middle, of course it failed. Continuous framing members are required from the floor to the roof. They built in a sill plate in the middle. Are building permits required where this was built?
If you look at each vertical stack of windows, there are headers at the top of each stack. And there are king and jack studs on the sides of each vertical stack all the way up to those headers.
The wall units are built in sections that intersect but they do not interlock. No shear resistance between the square sections, they are just stacked like boxes. Even a high wind would have passed right through if it were built correctly.
Looking at this picture, I'd be most concerned with this layer of vertical framing being broken up (circled in black). I don't understand why it was done like that.
Above that level on the gabled end wall, as mentioned, the window framing supplies little to no support to the roof, just the end rafters.
I'd have liked to seen a video of it in failure. Someone should send it to an engineering college for the students to model and put it in a wind tunnel.
I just got off the phone with the wife. This is their farm, they live in a other city. He has a new movie coming out in April and this project is kind of an idea he had that he asked his ranch hands to do. They hired out the foundation and feel it was done correctly because it was done by a pro. The ranch hands just winged it and they do not have a lot of experience. One of the worked for a contractor in Georgia when he was younger building tract homes. They now understand that they made a huge mistake in how they did this and they are now going to hire an engineer to design the room. They want to hire me to oversee it, but I declined. Its farther then I want to drive. They also agreed with me that they are blessed that it collapsed now and they get to start over and do it correctly this time.
