Buying Advice New L3560 Limited and Standard Versions
   / New L3560 Limited and Standard Versions #101
Well, it's here. Working today so not much time was taken to get a feel for it.
I think I might be over the weight rating on the suspension seat.
I can't believe I'm saying this, but I think there might be to much foot room. It's hard to find the pedals by feel. I'm sure I'll adjust.:p
You can tell where all the weight that it has on the standard L went. Back end is beefy in comparison to the L3301. Tires, despite both having R4s, have much more area between the bars on the L3560. Should have more pulling ability.
   / New L3560 Limited and Standard Versions #102
Glad you are happy with it.
I priced one yesterday. $41.5k with FEL, 62" blower, block heater, 3rd function and forks. Like you, I do not need the other stuff included in the standard cab, but will add lights.
   / New L3560 Limited and Standard Versions #103
Be aware the section of the harness for the front lights is missing. Your dealer will have to do some finagling. Right now I have a rear kit split, one light on front, one on back. After dark tonight I'll see if that's sufficient or if I want to go through the hassle of wiring LEDs at each corner.
   / New L3560 Limited and Standard Versions #104
Thanks for the warning. If figures they would make it difficult to simply add the lights. I do not work at night but nice to able to if needed. Adding LED's makes sense
Mad,
You know you can’t get a new L3560 LE and not post pictures. It’s against TBN rules. Cough’em up buddy!
   / New L3560 Limited and Standard Versions #106
Mad,
I'm in the office today. Will post when I get home.
   / New L3560 Limited and Standard Versions #107
As promised.
And a bonus pic of walking the dog yesterday, just to make all you snowbound posters jealous.
   / New L3560 Limited and Standard Versions #108
Good evening!
Looking to purchase a 3560 LE. For those that have purchased would you be able to provide height of tractor from concrete surface to top of cab. i have 95 inches clearance. I believe there is room but maybe by an inch? Your help is appreciated. thanks Brent
   / New L3560 Limited and Standard Versions #109
Good evening!
If you are worrying about an inch or 2 you really need to specify R1 or R4 tires as that can make the difference. Tire pressure can cause an inch of height difference in some cases.
   / New L3560 Limited and Standard Versions #110
i would be putting on the Titan Turfs. Salesman said they were the exact size of the R4's. Based upon that i understand that would be roughly 94 inches in height. For those that have purchased the 3560 cab tractor with R4's i would appreciate a measurement. Your help is appreciated. Thank you so much. Brent
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2016 Genie S-45 4x4 45FT Telescoping Boom Lift (A55787)
2016 Genie S-45...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
UNUSED LANDHONOR SGB-11-72W 72" GRAPPLE BUCKET (A54757)
UNUSED LANDHONOR...
