Buying Advice New L3560 Limited and Standard Versions
   / New L3560 Limited and Standard Versions #101
Well, it's here. Working today so not much time was taken to get a feel for it.
I think I might be over the weight rating on the suspension seat.
I can't believe I'm saying this, but I think there might be to much foot room. It's hard to find the pedals by feel. I'm sure I'll adjust.:p
You can tell where all the weight that it has on the standard L went. Back end is beefy in comparison to the L3301. Tires, despite both having R4s, have much more area between the bars on the L3560. Should have more pulling ability.
   / New L3560 Limited and Standard Versions #102
Glad you are happy with it.
I priced one yesterday. $41.5k with FEL, 62" blower, block heater, 3rd function and forks. Like you, I do not need the other stuff included in the standard cab, but will add lights.
   / New L3560 Limited and Standard Versions #103
Be aware the section of the harness for the front lights is missing. Your dealer will have to do some finagling. Right now I have a rear kit split, one light on front, one on back. After dark tonight I'll see if that's sufficient or if I want to go through the hassle of wiring LEDs at each corner.
   / New L3560 Limited and Standard Versions #104
Thanks for the warning. If figures they would make it difficult to simply add the lights. I do not work at night but nice to able to if needed. Adding LED's makes sense
Mad,
You know you can’t get a new L3560 LE and not post pictures. It’s against TBN rules. Cough’em up buddy!
   / New L3560 Limited and Standard Versions #106
Mad,
I'm in the office today. Will post when I get home.
   / New L3560 Limited and Standard Versions #107
As promised.
And a bonus pic of walking the dog yesterday, just to make all you snowbound posters jealous.
   / New L3560 Limited and Standard Versions #108
Good evening!
Looking to purchase a 3560 LE. For those that have purchased would you be able to provide height of tractor from concrete surface to top of cab. i have 95 inches clearance. I believe there is room but maybe by an inch? Your help is appreciated. thanks Brent
   / New L3560 Limited and Standard Versions #109
Good evening!
If you are worrying about an inch or 2 you really need to specify R1 or R4 tires as that can make the difference. Tire pressure can cause an inch of height difference in some cases.
   / New L3560 Limited and Standard Versions #110
i would be putting on the Titan Turfs. Salesman said they were the exact size of the R4's. Based upon that i understand that would be roughly 94 inches in height. For those that have purchased the 3560 cab tractor with R4's i would appreciate a measurement. Your help is appreciated. Thank you so much. Brent
UNUSED 72" HYD ROCK GRAPPLE (A54757)
UNUSED 72" HYD...
2018 Land Rover AWD SUV (A55758)
2018 Land Rover...
2020 ANTHEM 64T DAY CAB (A54607)
2020 ANTHEM 64T...
2017 Jaguar F-Pace SUV (A55758)
2017 Jaguar F-Pace...
183 (A52705)
183 (A52705)
2015 Mitsubishi Outlander Sport SUV (A55758)
2015 Mitsubishi...
