careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,822
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
I lifted the 3 point with the box blade then shut the tractor off. It took 10 minutes for it to drop to the ground. Pretty sure I can live with this.
Mines the same. Which I can live with. If you absolutely don't want the 3pt to fall use the lock between your legs. Then all you have to remember is open it before you go to lift the 3pt.. Lowering is no problem, It's locked and not going to happen but lifting will cause a dead head and your going to hear it!!
When it has sat for awhile and does fall that's no big deal to me either since when I start it back up it raises back to were I left the handle. Your Good then. Not enough Hyd. pressure to effect the starter. Until the motor starts and then the pump has to build up it's pressure.
As far as the loader can't help much on it. But have a opinion it just maybe in the controls.
