Skunk behind barn- alive but won't move
/ Skunk behind barn- alive but won't move #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
Found a skunk behind my barn this afternoon. At first I thought it was dead since it was in an open pasture area and not moving. Then I saw its head bob up and down a few times. That's its only movement-- head bobs up and down once in a while, then head back on the ground and no movement.
I presumed it was rabid, but did a little research and now I am not sure. I'm leery to "let it be" since if it *is* rabid and a coyote gets it tonight, the coyote is presumably rabid. And I read that if I shoot it, blood, etc. can infect other local game (or me) as well.
Apparently pregnant females can forage during the day for food or to feed young ones if they have given birth. So the old advice that any skunk out in daylight "is rabid" is apparently not true.
I have a trap but since it's not moving that's not going to work. So I'm not sure whether to let it be until morning or take care of business now?
Any ideas?
/ Skunk behind barn- alive but won't move #2
22 cal NOW...
/ Skunk behind barn- alive but won't move #3
What he said, then take your BH and bury it as deeply as you can, preferably with a big rock a couple of feet above the carcass.
/ Skunk behind barn- alive but won't move #4
Absolutely go shoot that thing now!
Move it with the bucket, and bury it with the back hoe.
But get that thing dead and underground before something else gets ahold of it.
I went back after posting to check it out. It was shaking and shivering, alive but with flies buzzing around it.
As suggested, a .22 and a backhoe were the right combination. I put some plywood and cinder blocks on top of the excavated area.
/ Skunk behind barn- alive but won't move #6
Sure glad I never woke up behind your barn at sunrise not knowing where I was after one of those nights out drinking.:gloomy:
/ Skunk behind barn- alive but won't move #7
Had two skunks like that last spring... Came right up to the house and workshop. My dogs somehow knew they were sick and left them alone. One started a slow, non-threatening lumber toward me. I shot it with a 22 in the body then made sure it was dead, used sticks to get it into a trash bag. After putting in another heavy-duty bag I tossed it in the back of the truck and drove it into town to the Health Department. A poor guy there cut off its head and shipped it to their lab. Few days later they confirmed it was rabid. The vet said there are several kinds of rabies. One of them is the "dumb" form where the animal is just sluggish to the point of being still - but never really threatens anyone. Other kinds make the animals much more aggressive and dangerous. The second skunk a month later also tested positive for rabies. They really like to have them tested so they can map out where rabid animals have been found. It helps them warn folks when the danger level is high.
/ Skunk behind barn- alive but won't move #8
Good job. Put it out of it's misery, and prevented anything else from getting it.
/ Skunk behind barn- alive but won't move #9
Sure glad I never woke up behind your barn at sunrise not knowing where I was after a night out drinking.:gloomy:
You'd probably get the same treatment around here.
:laughing:
/ Skunk behind barn- alive but won't move #10
Can you still get quick lime these days. Been in suburbia for a number of years but once upon a time if we killed something we were suspicious of out came the post hole digger, 4' deep a couple of cups of quick lime and then refill and tamp the hole. Most times we did not have a back hoe available and were not burning brush piles.
/ Skunk behind barn- alive but won't move #11
Any ideas?
You can't get rabies from the blood.
/ Skunk behind barn- alive but won't move #12
Had a sick racoon in my back yard; called animal control and the guy came out, picked it up and put it in a cage. I asked him if it had rabies; he said more than likely distemper.
Skunk update:
I checked the hill above the area where I killed the (rabid) skunk. It's pretty thick with downed branches and limbs, and in shaded / filtered sunlight from the full tree canopy above.
There is also a skunk aroma. So I suspect this is the location of the den where the skunk I killed originated from. Presuming it was rabid, and with a den so close, is there anything precautionary I should do? Other than keep a .22 handy when in the area?
/ Skunk behind barn- alive but won't move #16
Skunk update:
You might notify the county or state health department. It can't hurt, and they might be able to do something.
/ Skunk behind barn- alive but won't move #17
I didn't realize that, it's a good thing to know. When I killed the skunk in my turkey pen I took my 100K BTU propane burner and burned all of the blood.
/ Skunk behind barn- alive but won't move #18
Skunk update:
Nope. Just be on the lookout for more of them.
/ Skunk behind barn- alive but won't move #19
I had one like that, I threw it in the burn pit and incinerated it. Guess what the smoke smelled like :0 Next time Ill dig a deep hole.
/ Skunk behind barn- alive but won't move #20
I shot a skunk near my house one time and it turned out it had babies. I could hear them crying afterwards. I felt a little bad but it just cost me a few more shotgun shells to take care of the problem.
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Caterpillar 24in Digging Tooth Bucket Excavator Attachment (A59228)
Caterpillar 24in...
2024 MECO M-Y 4-Passenger Electric Car (A59231)
2024 MECO M-Y...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
CAT 930M (A58214)
CAT 930M (A58214)
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
