Just joined
/ Just joined #1
boomer2480
yammer ym 165
Hi all. My wife of 50 years passed away may 3rd and I sold everything in San Diego ca and moved to comanche Texas.
I bought a house on 2 1/2 acres and bought a yanmar ym165 tractor to maintain the drive way the drive way and it has a large brush cutting deck powered by the pto. It has been a great little tractor but I just lost the hydraulic pump and am waiting for it to arrive. Could anybody recommend what hydraulic oil to use in it. Thanks in advance for any info you can give me.
/ Just joined #4
:welcome: to TBN...enjoy.
/ Just joined #5
Hi and welcome to the forum! :welcome:
I'm going to move this thread over to our Yanmar section.
You should find plenty of advice over there.
:tractor:
/ Just joined #7
These are so simple to maintain and I believe this came from either or to what Winston said. The only two choices I have or even had back then. I think it was Walmart though. Your after the JD. 303 or equivalent. I'm pretty sure that is still correct for a 1980-85 165. 6 forward and 2 Rev. Gear........
/ Just joined #8
Welcome to TBN and I am sorry for your loss.
As for the hydraulic fluid as a few others have said, use JD 303 or equivalent. Can be found at Bomgaars, TSC, Wal-Mart and most farm stores.
/ Just joined #9
No Bomgaars around here, never even heard of it?
We do have Agrisupply in this area and that is my main choice if i happen to be going that way.
/ Just joined #10
We're big time now with a TSC. even. That pic. may have been TSC.. A friend in N. Ga. was looking for a crazy certain spec. which back then best I send him a pic. so I kept it. It was for his shop come to think about. Not Tractor or Auto. related. May have been a piece of equipment?
/ Just joined #11
Since Yanmar has been making CUT tractors for John Deere for decades, I refereed to the JD website. Mine came up as J20C. Thus, at TSC or any other coop farm store, make sure it meets the J20 A-B-C-D requirement.
I just changed mine recently. The YM2610 took 19-quarts! It has the reusable screen olefin filter on a stainless steel cylinder. To clean it, Hoye recommends diesel with a tooth brush and then rinse with brake cleaner.
/ Just joined #12
Sorry about your loss. Welcome to the TBN community and hope you can enjoy life there in Texas. I used to live there; nice people.
My wife and I have had our YM165D since it was new. Never a problem with it. I had loaned it to a neighbor when a flood happened and tumbled it down the river for half a mile - now rebuilding it.
As for the hydraulic oil, that oil is used for the gear box and the hydrualics both. There are Operator's Manuals that come up for sale on Ebay all the time. I'd get one because there are tricks in it that you need to know... For example, there is a washable wire transmission oil filter than fits down low below your right foot and you need to take that out and clean it at least once every ten years or maybe when you change that oil. If you do that carefully, you can use that filter forever. Same is pretty much true of the air filter with the sediment bowl.
For hydro/transmission oil I always just used JD303 back in the day...but that oil isn't made anymore because some of the ingrediants - like whale oil - aren't available today...which is good.
In fact, be a little careful because the out of date lubrication standard that JD303 used to make their oil is quoted by a lot of cheap aftermarket oil makers simply because the name is recognizable and the standard for making the oil no longer exists.
So what I do is buy a name brand dual purpose transmission/hydraulic oil. The Yanmar 165 doesn't require all the specialized additives because it is so basic. What I'm using right now is New Holland AMBRA Multi G 134. Might as well get name brand oil - it is cheap enough and will last for a decade.
What is most important is the coolant. It should be no more than 50% ethylene glycol. Your YM165 DOES NOT have a waterpump. It is a thermosiphon type of cooling system like an old 2 cylinder JD. So the mix of water and glycol is important. Too much antifreeze and it won't cool well. And be sure to keep the radiator clean. In fact, check that there is some stuffing around the fan shroud so that the fan pulls air through the radiator instead of between the heavy plastic fan shroud and the side of the radiator.
If you keep the cooling up to snuff that tractor should last another 40 years.
Here are some old YM165D brochures for your enjoyment. Ask any specific YM165D questions....I ought to know the answers by now.
luck, rScotty
/ Just joined #13
luck, rScotty
OK, I get it. It's a smaller tractor, a SCUT.
Attached is a PDF for the JD Fluid Capacities and the proper fluid. Should there be a close or exact engine match, then using the newer spec JD fluid should work. Most of the models in this list are rebranded Yanmars as John Deere's. The 2TR13A is similar to the CUT JD-650 in engine size.
Look down the listings. The very tiny engines are listed first and work up to the big sized stuff. Ignore the Riding Lawnmower as yours is a real Lawn Tractor or better.
  • JD Fluid Capacities - Turf Equipment and CUT tractors.pdf
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
