Tilt trailer
/ Tilt trailer #1
450
New Member
Fairbanks, Alaska
Branson 3725CH
Has anyone converted a hand pump (full tilt) trailer to a powered tilt or gravity tilt? It so how was it and where did you get your parts? This is a H&H 20 full tilt trailer. Thanks
/ Tilt trailer #3
I did convert the same exact trailer. I bought the power up / gravity down unit through Graingers, the cylinder and hose from Surplus Center. I put the unit inside a Tractor supply box I mounted to supporting steel frame for a winch in the box as well. If I recall I believe the power unit was around $500, Cyl and hose was another $125, and box about $100. The rest of material I had. In all was around 800-850. A single acting cylinder worked great for power up /gravity down only needing one hose. I looked for a cylinder with a similar length closed, same stroke, and larger piston diameter. I bought the higher capacity hyd. fluid box for the pump (square box) but the original round reserve would have been fine.
The original cost of a H&H with power unit was $1600 more so I saved about $800 or so.
I bought my trailer new in 2006 but by 2014 had outgrown the 7K weight rating so it was sold and replaced with my PJ 22' full tilt 14K.
The link Fallon listed has a pump similar to what I used.
/ Tilt trailer
George, was your pump unit double action or single action? I would be fine with gravity down if it would stay up until I let it down. One hose would be nice. Thanks for the help.
/ Tilt trailer #5
As shown in my first pic there is a round black knob. Pushing the knob one way engaged the pump to fill the cylinder and tilted the bed. When released the bed stayed tilted. To lower the bed the knob was moved the other way relieving cylinder pressure. You could vary how fast or slow it lowered.
/ Tilt trailer #6
Watching. I just put a double acting pump in my amazon wish list for my exact same trailer.
/ Tilt trailer
Lenny, when it warms up here I will convert mine to HPU. It’s still snow on the ground here so it will be a couple of months.
/ Tilt trailer #8
I have read of a couple of times where guys converted a bottle jack or engine cherry picker from manual to hydraulic in the past.
I am going to use a regular hydraulic cylinder though.
It’s a lot of pumps to get to the ground sometimes, huh?!
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
Freightliner CST120 (A63689)
Freightliner...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2024 MODASA  MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
