What is the best battery operated chain saw
/ What is the best battery operated chain saw #101
Not sure where you are getting your chains, but over $40 is a complete rip-off. I can get replacement chain for the Milwaukee M18 Fuel chainsaw a whole lot cheaper than that. The saw comes with a 16" bar, 0.043" gauge, 3/8" Low-profile chain with 56 drive links. Baileys (who is not the cheapest place around to buy chains) sells a few options:
WoodlandPRO 34LP56 for $13
Oregon 90PX056G for $17
Stihl 61PMM356 for $22
I'm not a big fan of the Woodland Pro, but the other two manufacturers make good chains.
I’d bet that the Stihl chains are made by Oregon anyway.
/ What is the best battery operated chain saw #102
Does Oregon make some of the stihl chains? Mine all say Stihl on the drivers.
/ What is the best battery operated chain saw #103
It appears so...
Amazon has it for about half or a twin pack for $47.
#3670 (71 PM3 72) OILOMATICョ saw chain
OILOMATICョ CHAIN 1/4" STIHL PICCO 14" bar length
MSA 200 C-BQ 14" bar
/ What is the best battery operated chain saw #104
Just checked Baileys... $29.99 which sure beats $40 until Baileys adds the $9.99 shipping making it 39.98 which is what I paid plus tax.
Also, if I am reading it right there is no other option from Baileys for the 1/4" pitch but Stihl.
I would love to save but it seems Bailys is the same as the Stihl shop where I bought my 3 loops.
Stihl 14" 71PM3 Chainsaw Chain Loop (1/4 x .043) 72 Drive Links, SKU STL 71PM372
Swiss made OEM chainsaw chain from Stihl. Stihl saw chain is made for the most demanding cutting conditions and is loaded with professional features. Stihl chain has Oilomatic drive link lubrication slots, which funnels oil directly to the rivet to reduce wear. Stihl chain is also pre-stretched at the factory, which helps eliminate excess adjustments during break in periods. 71PM3 is part of the Stihl Picco Micro 3 series.
This chain has reduced kickback and low vibration features. 71PM3 is a narrow kerf (.043") low profile saw chain designed for lightweight chainsaws and pruning saws. The combination of reduced kickback and low vibration features with improved cutting and boring efficiencies make it a favorite of professional arborists.
/ What is the best battery operated chain saw #105
Brushless Makita 36V, 14". Has an Oregon Bar and Chain. Part of Makitas push into 36V by using 2 of the existing 18V Batteries.
We have a String Trimmer/Brush Cutter, and the Chainsaw and both work incredibly well. I would never have thought them as replacements, but haven't picked up either of the 18" .30's or the Sthil Trimmer since we bought them. I did change the String Bump for a Tanaka push pin and picked up 2 spare chains from Oregon. I prefer to swap the chain in the field and sit with a beer later sharpening.
All I can really say about both, without sounding like a commercial, is yes they do their job, do it well, have never complained, battery life is excellent and unexpected, wife acceptance is through the roof. She will even grab the Makita for some trim work, rather than wait for me to add it to list. Also she grabs the String Trimmer snaps in the batteries and has no problem trimming around flowers, hedges, house, walk way, etc. Even has spun on the blade and smacked the thicket around. :D
You pay for the privilege, but if asked if I would do it again, after over a year of use, the answer is absolutely yes. So much so, I am salivating over the Compound Miter....
Ohh crap, forgot about the Hand held blower. It has become such a standard use item. I don't even think about it. Used almost daily to blow leaves, sticks, acorns, nuts, dirt, what ever, from walks, driveway, porches, etc. Use it to blow dust out of the tractor and debris from behind the seat, and oh so many things. Such an easy and quick grab, anyone around here has no prob using it without hesitation. Adjustable air and crazy power. Full tilt, using a 6 setting (which is rare tbh), it will go about 1/2 an hour to 45min, normally we rarely need to re-charge.
Makita batteries charge in 15min. From dead to over 80-90%.
Feel free to ask any questions.
/ What is the best battery operated chain saw #106
i have the milwaukee chainsaw. it does the jb - but you really have to use the high output batteries that i over 200 bucks for one. if you try to use the batteries for drill that is less then 9 .0 it only runs for 10 mins. the high output battery lasts for about 20-30 mins thru 16 inch oak logs. i prefer to use gas as i can keep going without carrying the batteries with me but the battery saw is perfect for limbing or that 10 min job so i keep it in my work van at all times. If I knew i was going to cut down a tree - I am going with my gas saw - period.
/ What is the best battery operated chain saw #107
How many cuts through 10" diameter logs (mix of maple, birch, ash, oak) do you estimate the saw will make before a recharge?
Thanks,
/ What is the best battery operated chain saw #108
Bailey's WoodlandPRO 71SC is 1/4" .043. I find the Woodland Pro chain does not stay sharp quite as long as Stihl but it's cheaper. I use it for larger saws for felling and bucking.
I group up my Bailey's orders to amortize the shipping cost across many items. Also the gas to drive to the Stihl dealer costs about as much and it takes more of my time.
/ What is the best battery operated chain saw #109
No. Stihl makes their own chains, and there has traditionally been a noticeable difference between Stihl and Oregon. Both seem to me to cut about the same (assuming you chose similar types of chain). Stihl seems to be a bit harder metal, so tends to hold an edge longer, the oregon chains are easier to sharpen. Either one is toast if you hit something you shouldn't when cutting.
For years, Husqvarna chain was just rebadged Oregon chain. within the few years, Husqvarna started making there own (some styles may still be rebadged Oregon. I'm not sure if the Husqvarna facility can meet all of their needs.)
Not too long ago, both Husqvarna and Oregon introduced new chains. If I remember correctly, for Husqvarna, it's the "X-Cut" family of chains. Oregon's new offering is called "SpeedCut". I've not used either myself yet, but have heard they are good performers, and the durability/hardness is more similar to the Stihl chains. I'll be picking some up one of these days to try it out.
/ What is the best battery operated chain saw #110
I've never had anything bad Makita... it was my first cordless back around 1983 and still have it...
/ What is the best battery operated chain saw #111
Stihl Dealer is on the way to work... literally just pull in driving by.
I was surprised at the cost of the chain as I had borrowed my brother's battery operated Stihl arsenal plus polesaw to use around my place and wanted to pick up a couple of new chains to give him when I brought it back.
When I called him to see if I could keep it longer so I could do some work at Mom's he said no problem... commented on the cost of Chain and he said those "Little Suckers are Expensive" same chain fits Stihl polesaw.
/ What is the best battery operated chain saw #112
If your batteries less than 9 AH only last 10 minutes on a drill, then you have either battery problems or drill problems. My years-old M18 Milwaukee 3 AH batteries last far longer than 10 minutes. Those are the smallest batteries I have. I also have a number of 4.0 and 5.0 Amp-Hour batteries. I used them when I was working with a solar PV installer, spending all day torquing down hundreds of clamps on a standing seam roof to create mount points for a 50 KW array. I would replace the battery when we broke for lunch, even though it still had usable charge.
I just bought my first high output M18 batteries: a 12.0 and a 6.0 AH battery packed with one of their Rapid Chargers for a total of $249. (See the thread Good deal on large capacity Milwaukee M18 Cordless tool batteries for more info). That's the same price they normally charge for the 12.0 AH battery alone.
/ What is the best battery operated chain saw #113
I've had a lot of Makita cordless tools, several corded tools as well. But my last two cordless drills were duds. One came with nickle metal hydride batteries (just before lithium really started catching on). It had a 3 speed gear box and within a short period the fasted speed stopped working. Not really a show stopper but a few months later the middle speed went and then finally the slow speed. The cost of the part was more than two new drills so I replaced it. The replacement had the trigger die not long after the warranty expired. The price for parts is insane so I switched to Milwaukee. Kind of sad but after spending that much on a professional tool it would break.
/ What is the best battery operated chain saw #114
Sorry to hear that... I recommended Makita cordless when asked by wives of friends when they were Christmas shopping... some of the Box stores had holiday specials and I was responsible for several sales...
My 1980's Makita stuff is all working well... battery and corded... the planer, chopsaw, drills, flashlights, etc...
One thing I have always done since day one with nickel metal hydride batteries is ONLY charge when flat out dead... I would leave the switch on or put the battery in the flashlight until dead and then immediately charge... a battery engineer told me this was best. I still have the 1985 DC Makita charger bolted in my service van...
Ironically, Milwaukee after also being a favorite of mine left me high and dry twice...
Once was a Christmas gift set for my niece... lithium batteries... there was one battery that would not charge after being used only a few times... I sent the battery to Milwaukee and warranty denied... saying it had been exposed to water??? I then asked to have it back so I could have someone else look at it and was told this was not possible... I wanted the battery engineer friend to look at it.
So Milwaukee kept the battery I paid for, declined to replace it and refused to return it...
The second problem is with a Milwaukee Pistol corded drill... the switch went bad... had it 4 years... used several times every year with a sink snake... was told the switch is no longer available... not possible to get...
Probably just my bad luck...
Milwaukee service station is also very poor here... 4 to 6 weeks unless a $20 expedite fee is paid for 7 day turnaround depending on part availability...
/ What is the best battery operated chain saw #115
Thanks for sharing your Milwaukee experience.
I have several older Milwaukee corded tools, but none battery powered.
I have only Makita and DeWalt battery powered tools, and they have been great.
I will eliminate Milwaukee from any future consideration, based upon your report of customer indifference.
/ What is the best battery operated chain saw #116
I did buy a replacement battery for her and no problems to report... I think it was $70+
Bought a Dewalt Cordless for work in 1995... had batteries rebuilt once and no complaints... especially at the price point.
Have a biscuit joiner too and it has been great and much less expensive than others at the time... I used it a lot in the Hospital adding cam locks to hundreds of cabinets to meet new requirements… the biscuit joiner is perfect for cutting the slot...
/ What is the best battery operated chain saw #117
My Milwaukee 18V saw came earlier this week,, then, I ordered a couple replacement chains.
The replacement chains came today,, I figured I would wait to post about them until they arrived,,
2 Pack, Oregon 9PX56G Low Profile 3/8-Inch Pitch .43-Inch Gauge 56-Drive | eBay
The eBay listing is for two chains,, for $19.87,,, free shipping for both chains.
That works out to be $9.93 per chain,, delivered,, tax included,,,
Heck, that is about $2 more than the cost of having a chain sharpened,, and IMHO, a new chain always cuts better than a re-sharpened chain.
Also, this is my third electric chainsaw,,,
I found that the slightly slower chain speed of the electric saw greatly increases chain life..
I will probably not use up 3 chains for quite a while,,,
I expect,, for my use, the chains for the Milwaukee will get tossed if they are dull,,,
Oh, yea,, I cut the limbs from a 22" DBH red oak that was blown over,,
The Milwaukee cut all the branches to firewood length,, and the battery still has some charge left.
My neighbor cut the main log with his Husky gas saw,,, while I used the Milwaukee.
I really got tired of hearing the engine on that Husky,:laughing:,, boy I like the electric saw,,, :thumbsup:
/ What is the best battery operated chain saw #118
Very impressive cost per chain...
But seems there is always a catch... the website states:
"We do not ship orders to California"
/ What is the best battery operated chain saw #119
That's because saw chain is known to cause cancer in the state of California. :laughing:
/ What is the best battery operated chain saw #120
You found some great pricing on those chains. I did not look much for best price in my links above, just went to a place that I knew would stock it.
If that's true, you should find a new place to get your chains sharpened. It's not difficult to get your chains resharpened to better than new. The problem is that a whole lot of people just don't know how or don't take the time to sharpen chains correctly. The typical hardware store flunky probably had 15 minutes of "training" on their chain grinder.
When sharpening by hand it's easy to get good results with the use of an appropriate guide. It does take a bit of practice. (In the course of my chainsawing, I've run into dozens of people who think they are great at sharpening chains freehand - just a bare round file without any guide. I've run into 3 who actually are good at it and can match or beat new-out-of-the-box performance.)
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2024 High Country Cargo 6x12 Enclosed Trailer, VIN # 7FWBE1217R1035595 (A61166)
2024 High Country...
2012 KENWORTH T800 KILL TRUCK (INOPERABLE) (A60736)
2012 KENWORTH T800...
